You're welcome.
This one on Amazon says it has a 3" nosepiece: https://www.amazon.com/Astro-Pneumatic-4 ... 61&sr=1-17
Passenger window regulator well and truly hosed up....
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
bajaman123
- Year and Model: 1999 S80 T6
That one looks like it would be perfect, and very reasonably priced too.vegasjetskier wrote:You're welcome.
Once again...I can't thank you enough for your help.
vegasjetskier
Bajaman, I wonder if you could straighten the bent arm and then weld some reinforcement along the edge?
Also, I think it would be prudent to look for the cause of the window binding up in the first place. It must have really been stuck to cause the arm to bend like that. If you don't correct it, the new regulator will probably suffer the same fate.
vegasjetskier
Here's a PDF of the VADIS procedure. It's for the driver's door, so it's a mirror image of what you're working on:
bajaman123
Thanks for the PDF!vegasjetskier wrote:Bajaman, I wonder if you could straighten the bent arm and then weld some reinforcement along the edge?
Yeah, I was thinking that same thing. WHY did it do it in the first place? I do think I will try to repair the existing one after I find out what was causing the bind.
bajaman123
SUCCESS! I was able to straighten on the arm once I took it out and then re-installed it, lubed up the window channel, and all is well again.
Thanks so much for all the help.
Here is a picture of the riveter that I bought, as well as the rivets. I was not able to get the factory rivets but found some that worked admirably well, from a company called SUREBONDER. These are multi-fit rivets that worked really well.
- riveter.jpg (49.14 KiB) Viewed 1916 times
- rivets.jpg (48.72 KiB) Viewed 1925 times
vegasjetskier
Excellent. Where did you get the riveter?
dcarlson12
- Year and Model: 1997 850 T5
- Been thanked: 2 times
Just wondering what you and perhaps others use for lubing the window slides.
This was done on one of my doors/windows by the dealer for the previous owner but would like to save the labor cost if and when I need to do it but would like to know what specific type of lube to use i.e. probably not axle grease??
bajaman123
I got the riveter from a specialty tool store locally, paid $60 for it. There are others out there of the same design for half that price if you search around a bit.
For the lube, I used Liquid Wrench white lithium grease in the spray can. Use care to keep it from getting on...EVERYTHING..., and a little dab'l do ya!
This forum is awesome.
- 362 Views
Last post by Pretribrapper
- 746 Views
Last post by davidlevine08
- 669 Views
Last post by rgk
- 2536 Views
Last post by zwieback
- 630 Views
Last post by mjsteps
