Hello Everyone,
This site in incredible. I am in process of removing rear driveshaft from my 99 xc70 to make it front wheel drive.(Driveshaft is bad and I am curious if I will feel any slight increase in power w/FWD) What size torx do you use to remove driveshaft? The closest size I have in my set is a T40 and it was stripping. Has anyone removed the driveshaft and made a generic plate/ cover to place over viscous coupling to prevent debris from going inside? Thanks...
Remove rear driveshaft- 99 xc70
Some people on the V70xc forum have removed their driveshafts. Check to make sure what the bolts take, I think they take an allen wrench rather than Torx. Here is a picture of the front coupling.. The coupling was bad on mine but I replaced it.
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
- Has thanked: 2857 times
- Been thanked: 1332 times
Commlend, if you do remove it, please post back to this thread any observations/impressions you have. We don't have anything on this; I searched the far reaches of the site just now and turned up nothing.
Thanks in advance!
Thanks in advance!
Just one other suggestion. In other posts I have read that it's important to mark the bolt locations if you plan to put the same driveshaft back on at some point. This is for balance.
vlvman
- Year and Model: 04 S60R 94 850T 89
I have a 04 S60R AWD. The awd can be turned off simply by activating the parking brake light by lifting parking brake 1 click, or connecting a switch across the parking brake switch to turn off the awd. If the parking brake light is on AWD is off.
daren1
- Year and Model: V70 XC AWD 2.5LPT
hi guy,s ,sorry and girls , i'm new to this site so hope this (my first post) ends up in the right place !
i removed my prop/drive shaft (gearbox to rear diff) and had it completely re-built and balanced using GKN parts , prettymuch the same as land/rangerover with universal joints i can change myself (internal circlips) and a centre / hanger bearing i can remove. this set me back £360 from a prop/driveshaft company i worked for in the uk.
while it was being re-built i drove about 1500 miles just frontwheel drive and found loads and loads of torqu steer and about 25% loss of confidence cornering. i didn't notice any improvment in the mpg. (17 mpg town,22-24 motorway) what i did find was after towing a 23 ft caravan about 800 miles with oddsize tyres had killed what was left of my awd , and when i inspected the two driveshafts going into the rear diff , i had 2-3mm of play /orbital float ,where the shafts enter the diff and this was where the noise/rumble was being generated. iv'e since bought two rear outer cv/stub axles with abs rings from ebay for £30 each new, removed the rear driveshafts completely and just run with the stub shafts in. and boy what a difference , almost totall silence from the rear end! trully FWD.
i will re-fit and repair the awd system as and when funds allow . the improvment is worth it . for now it's up on axle stands having had new steering rack/stut top bearings(up/lower)drop links/sway bars /springs/wheelbearings/antiroll bar/brakediscs,pads .sorry about the spelling .lol!
hope this counts as a contribution!
th
th
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
It does!
Thanks for posting and welcome to MVS.
ummm more AWD fun
1: FWD owns AWD in reliability from 98-02 (USA market)
2: The first image has a ripped boot
3: If you strip the bolt you are in for some fun, go a little oversized and hammer it in there with all you can!
4: You don't need a place for the VC
5: It if VERY VERY common to remove AWD! I HIGHLY recommend it unless you have the funds and know how to work on the system yourself. I am going on a stock pile of 3X drive shafts, 4x couplers, and 3x bevel gears JUST for if I buy another AWD
6: The 03+ systems do NOT apply to this system so the ebrake will not work. The 03+ have the electronic Haldex VC so you can run sets of 2 tires instead of a complete set of 4 tires. As in you don't have to worry about the 3/32 tread difference from front to back. 03+ systems OWN 98-02 systems
7: if you want a drive shaft I got a good used one for ya
Summer: 2002 Triumph TT600
Fair Weather: 2001 S60 T5M
Winter: 2000 S70 AWD
Restoration: 1983 Mercedes 300CDT
- 10 Replies
- 7099 Views
Last post by SuperHerman
- 917 Views
Last post by jonesg
- 790 Views
Last post by Steve H
- 819 Views
Last post by cn90
- 23 Replies
- 4207 Views
Last post by Yarddogperformance
