putting a 960 TB on a N/A 850...
Craigd2599
Year and Model: 2007 S40.
Has thanked: 3 times
Re: putting a 960 TB on a N/A 850...
Post by Craigd2599 »
Good deal! I'll stop and see Jamie this week and see what they get for it at Waltrip
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
2volvoken
Year and Model: V70XC 1998
Post by 2volvoken »
I have just order'd a 960 "plate" from Don at waltrip volvo....he said it should ship today..........will post after install....I should have called them first,salvage yards wanted $125.00-235.00. It sounds like I'll have less than 20.00 for the plate, 2 new mounting screws and new gasket, from Waltrip volvo........Ken& thanks for all the help!!
'93 850GLT na 155,000 '98 V70XC 115,000 '99 C70 126,000
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
2volvoken wrote:... salvage yards wanted $125.00-235.00.
Looks like they've caught on to this trend and are taking advantage of it.
This is one of those strange times when a dealer is cheaper than a salvage yard.
Also -> Amazon link
Craigd2599
Go back and read carefully...the $125 was for the entire throttle body. He didn't ask for just the plate
Craig D
matthew1
Site Admin
Post by matthew1 »
Good point, but would a salvage yard sell just the plate? I've only bought from salvage yards a couple times, so I can't comment on the chances of that. One of those times they were reluctant to separate a MAF from the airbox top because it didn't want to come off easily. They would rather stand firm on the price of a MAF + airbox top and not make the sale than risk destroying one or both of those parts.
Whatever the case, even if they did sell the plate alone, after shipping it's likely to be as much or more than the dealer.
Also -> Amazon link
dan2286
Year and Model: 94 850 N/A 5 Spd.
Post by dan2286 »
matthew1 wrote:Good point, but would a salvage yard sell just the plate? I've only bought from salvage yards a couple times, so I can't comment on the chances of that. One of those times they were reluctant to separate a MAF from the airbox top because it didn't want to come off easily. They would rather stand firm on the price of a MAF + airbox top and not make the sale than risk destroying one or both of those parts.
It depends on what type of salvage yard it is. If they pull the parts for you, it can be somewhat limited to what kind of parts they will pull for you and the prices will be higher.
If it is a pull a part type yard, I have always heard there is kind of an unwritten rule that if it fits in your pocket, it is free. I have gotten who knows how many nuts/bolts, sensors, switches, etc. for free just because I stuck them in my pocket and never got questioned when I left.
Brian Mc
Year and Model:
Post by Brian Mc »
SO I played around with mine again this weekend. Took my body off my car and took it apart. This time I used lead plumbing solder to close the hole. It melts at a much lower temp- and I figure if somehow it works out- its soft so it should pass! (hopefully) :roll:
No for a driving update- I have an auto so its not as noticible a difference as with a stick. BUT- It does seem to rev much quicker the butt dyno says its a little faster. The biggest difference I notice is cruising around 2100rpm at 60 mph the car is MUCH more responsive to small pedal movements. Also the MPG computer has gone up quite a bit at this rpm range- maybe an extra 8-10 mpg.
I am going to run a tank thru with the trans on sport and a tank thru with the trans set on economy- I will let you know the difference.
Unfortunatly im 90% around town so I cant give a highway report but results look favorable!
2volvoken
Post by 2volvoken »
Yes 125.00-235.00 was for the whole throttle body. Here in northern Indiana 960's must not have been to popular as there are zero at the pick/pull type salvage yard....that is why I had no choice but to resort to trying to get a whole throttle body...the customer service at D.W. Volvo was terrific, if you can't locate a throttle body, call them...ask for Don or Jamie.
Craigd2599
I play hockey with Jamie...good cat
Craig D
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
Brian Mc wrote:SO I played around with mine again this weekend. Took my body off my car and took it apart. This time I used lead plumbing solder to close the hole. It melts at a much lower temp- and I figure if somehow it works out- its soft so it should pass! (hopefully) :roll:
Nice! I hope your soldering job is solid. I wouldn't want any off that stuff breaking off and going into the engine :shock:
2volvoken wrote:I have just order'd a 960 "plate" from Don at waltrip volvo....he said it should ship today..........will post after install....I should have called them first,salvage yards wanted $125.00-235.00. It sounds like I'll have less than 20.00 for the plate, 2 new mounting screws and new gasket, from Waltrip volvo........Ken& thanks for all the help!!
This seems like the way to go for most people. I think Volvo is about run out of its 960 throttle plate stock pile shortly. 8)
Ambitious but rubbish
