1998 GLT-70 coolant fan runs continually
raquette
Year and Model: 2010 xc90, 2007 xc70
Been thanked: 4 times
Post by raquette »
coolant fan does not shut off until the temp gauge goes to 0, then it will turn off after car has been shut off and siting for awhile. Last year I replaced he thremostat and temp has been running normal at mid gauge (not overheating).
I disconected the e-plug attached to fan shrould, which shut off the fan, but the motor developed a high idle, so I reconnected for now.
Is this the temporature sensor, if so where is it located?
thanks All.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Yes, it does sound like the temp sensor- it's located at the base of the thermostat housing- facing the radiator...it has 2 wires running out of it. Just make sure the connector is clean first before replacing it- but what you describe is typical when it goes bad.
raquette
Post by raquette »
Thanks MIJ, I'll check the connections before replacing.
raquette
Post by raquette »
Just want to report the ECT part was installed and problem solved, thanks again
MadeInJapan
Another satisfied customer! :lol:
crisleggett
Year and Model:
Post by crisleggett »
What if you replace the sensor in the therm. housing yet the problems persists? As soon as I start my 2000 S70 the fan begins to click on then off continuously.
MadeInJapan
Is your A/C on?
crisleggett
Year and Model:
My ac is usually on all the time. I keep everything on auto, and the temps here in southern AZ are mostly warm.
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Your problem sounds more like a low refrigerant level in the A/C system. Anytime the A/C compressor is running the radiator fan should kick on. If the compressor is cycling due to a low charge the fan will cycle as well.
crisleggett
Year and Model:
Ok I put a can in and nothings really changed. The pressure (level) was good. Do you think I may need another can? The fan is still running after I shut the car off too especially now that were getting into the upper 90s....
Thanks
