https://www.matthewsvolvosite.com/fix-a ... -tutorial/
Excellent Yeagermeister, thank you, and sorry it took so damn long to get that up.
Matt
Stuck glove box fix by Yeagermeister Topic is solved
Fix a Stuck Glove Box Tutorial
- Has thanked: 2857 times
- Been thanked: 1332 times
yeagermeister
- Year and Model:
looks good, man!
no prob on the delay. if it'd been my responsibility, it would have taken months!
(the other) sean
'94 855 5-speed
'02 lifted Nissan XTERRA
'94 855 5-speed
Thanks for the info and pictures on this.
I did choose to drill a hole in mine and because of your precise directions and measurements I was able to drill exactly where you said however I used a smaller bit so there was less damage. I also used an ice pic instead of a coathanger. I found this worked very well. As a result there is just a very tiny hole that is not too noticeable.
I did the fix as you described with a slightly different approach. I removed the release mechanism as I found it easier to work on and drill the hole. I installed the screw from the other side then cut off the head.
There is one slight catch though, There was a pin and spring on the underside of the mechanism that is not visable until you remove it from the door. When I removed it I could feel the preasure of the spring release from its' position which I was unable to see. I could not remember how the spring and pin on the underside re-attached nor could I figure out what it does so I installed everything without it just to see if everything works. Guess what it all works perfectly without the mystery pin and spring.
BruceRichards
- Year and Model:
Do you think the hold could be drilled from the top instead of the front?
Thank you so much for the fix. Instructions spot on. I used a 2mm drill which left negligible marking. For the pin I used a 3mm scred, drilled and tapped. I cut the head off and loc-tited it in just to be sure.
Thanks again,
Steve
Thanks again,
Steve
'94 850 GLE
captplanet
- Year and Model:
Your repair procedure was excellent! I got the job done in minutes instead of hours and the repair is nearly invisible! Thanks for the great pics! they were invaluable too!
captplanet
captplanet
David Hyman
- Year and Model: 850 Turbo Wagon 1995
This is an excellent guide to fixing a vexing problem. THANK YOU. It worked perfectly. GOOD JOB!
johngoulder
- Year and Model: 850auto 1996
i have just opened my glove box with your method it was perfect,i havent replaced my door trim,i bought a volvo lapel badge off ebay and placed it over the 3mm hole with double sided tape so i dont need the black&decker next time.
Thanks so much for the info.
Couple of points:
If you have a right hand drive the distance for the from the edge to the drilling point for the hole is reversed, rather than being in the same place as for a left hand drive.
I also put my screw in from the opposite side from yours (nothing to do with LHD or RHD) as I couldn't quite work out where your screw went and how it worked from the pictures. my screw directly replaces the pin that was snapped and screws into a hole I drilled in the actuator at the point where the pin had snapped off.
I filled the hole in the front with some filler which I will dab in with a dark grey marker or some paint.
Thanks again, great stuff saved me some serious bother.
Couple of points:
1997 850 AWD estate
- 12 Replies
- 3161 Views
Last post by darylrobert
- 2623 Views
Last post by pearhead1
- 2285 Views
Last post by glennvk
- 1442 Views
Last post by Pren
- 828 Views
Last post by SCK
