OK, i found two connectors in that spot, one looked as i was attached to an a/c line (at the firewall) i took a paper clip bent it into a 2 prong configuration and inserted it in to the plug part and even the connector, no engage. I saw another plug and disconnected it and did the same thing, nothing but the ABS light came on and then it went back off when i drove it. Any suggestions? I really appreciate you guys very much! It's 100 degrees here in Dallas and I'm trying to get this booger fixed.
Am I doing something wrong?
Thank you very much!
Matthew
S70 GLT/2000/A/C Clutch won't engage
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
The one on the A/C line next to the firewall is the correct on...make sure you use the paper clip in the one that is closest to the compressor- not the one closer to the firewall...then you'll need to turn your A/C on for it to work...did you do that? If it still doesn't work, then check fuses and still no, then your compressor's probably Kaput.
MadeInJapan
Did you pull a vacuum on the system like was mentioned above with the machine? If so, then was it tight...no leaks? If so, then did you fill with gas? After all of this, then you use the jumper wire inside of the connector that is on the A/C line WITH the A/C switch on inside the car...blower on high would be a good recommendation with temperature at lowest setting to make sure it comes on... if this still doesn't work then check all wiring to the compressor (did you disturb anything?)
getoffme31
- Year and Model: S70 2000
I don't think i disturbed anything on the replacement hose, but to give you the overall, the a/c system has not been charged in a few months, there is a small leak in the evaporator from when it worked. I found a two pronged clip on the a/c line just in front of the timing belt, i did the jump procedure, nothing. I also found another connector closer to the compressor like you said, it's right beside the place you normally charge the system, but it has three prongs. Checked all the fuses, no visual burn outs on the small fuse box, on the other fuse box there is that little black box shaped fuse for the compressor, i unplugged it , but i could not tell if it has blown. Just trying to get through the summer months with some a/c ya know lol. I know that i am nowhere near the capacity of knowledge with volvos as you all are. So thanks for being patient. I found a small black wire with a plastic housing , this was directly on the compressor itself, did not know what to do, so i came back on here.
Matthew
Matthew
- volvo2.jpg (59.59 KiB) Viewed 774 times
getoffme31
It's fixed! Thanks everyone!
MadeInJapan
Can you clue us in on what it took to get it going again...glad you got it sorted, but sort of stumped that there are no specifics.... Please let us know!!
- 831 Views
Last post by doublebug
- 820 Views
Last post by skippy
- 19 Replies
- 8655 Views
Last post by Roger_850T
- 954 Views
Last post by kaneelschep
- 1784 Views
Last post by MyS40T4
