Thermostat bolts
tailor
- Year and Model: 2004 XC90 2.5T AWD
- Been thanked: 2 times
There is good write up on changing the thermostat in the repair database. A good dollop of PB Blaster or similar will normally give good results. If possible do this a few days before and running up to tackling the job. The torx socket/ driver is important as well. Now may be good time to flush the coolant .
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
Abe Gottschalk
Mike-Halewai
- Year and Model:
I had to give my two torx screws a heck of a lot of muscle to get them out. I used a good set of high-end torx bits, almost stripped-out one of them, but each after enough muscle cracked loose.
Mike.
94 850 Turbo Wagon.
94 850 Turbo Wagon.
- Year and Model: Many Volvos
- Been thanked: 76 times
A lot of PB Blaster, soaking overnight, and slow and steady pressure with the best quality torx bit you can find will help. Once they break loose they are easy.
Volvo found the error of their ways and they have coated steel bolts for around $1.00 each at the stealership. Have the new bolts on hand to replace the old ones.
- 1330 Views
Last post by Nevada1906
- 26 Replies
- 5790 Views
Last post by mnorris23
- 13 Replies
- 4810 Views
Last post by nutmegrose
- 1483 Views
- 10 Replies
- 2536 Views
Last post by mickjenkins
