Volvo 240 rear brake light
Guest
One side of my brake lights do not work. The bulb is not the problem. Neither is the bulb holder. What should I look into next? Thanks.
40 years in volvos
Check to make sure that the bulb holder electric tabs and their connections to the printed circuit are clean. Next check the ground from the printed circuit to the car body.
Guest
Sorry to hijack the post....both of my brake lights are not working but all taillights are. I've checked all the obvious (fuse, bulbs and brake switch) that I can think of, still no luck. Anyone know what else should I check? TIA40 years in volvos wrote:Check to make sure that the bulb holder electric tabs and their connections to the printed circuit are clean. Next check the ground from the printed circuit to the car body.
SMerrill8
I found that the plastic parts were failing and it introduced rainwater into the bulb area, which continually fried the bulb.
Bobby Joyner
- Year and Model: 1986 240 dl sedan
I had the same problen on my 1986 volvo 240 dl & the contact that plug into the printed circuit board were coroded & dirty.
Used CRC electronic cleaner on the plug & receptical & now all is well. Bobby Joyner
- 1106 Views
- 3160 Views
Last post by Patman
- 442 Views
Last post by DeluxeRaccoon
- 14 Replies
- 2938 Views
Last post by crlande
- 23 Replies
- 39598 Views
Last post by DeeSi
