How to Repair Brake Pedal Position Sensor or Engine service
hi! I was repairing brake pedal position sensor on my S80 T6 y.2000, but I think is the same in all S80, S60,V70 etc. Here is link how to repair (clean) brake position sensor with photo instructions, exactly to CLEAN CARBON ROADS AND EVERYTHING FROM USED CARBON INSIDE WITH ALCOHOL ...is in Slovak but from photos easy to do. click here http://www.volvoklub.sk/viewtopic.php?f ... 7&start=10
Thanks for the great photos. This will really help if I ever have to do this.
Couldn't help noticing the dreaded carbon film strips. Though they don't get the wear the ETM seems to get, you could definitely see the carbon was starting to tear.
Also looked like you might be indicating poor solder joints on the PCB board? Seems to be a common failure point on other parts, like the ABS modules.
Couldn't quite puzzle out the Slavic, though. What kind of symptoms were you getting that lead you to the position sensor?
Again, thanks for the info.
ok, I will try to translate it to english}but with mz english?:)) ... symptoms were: cruise control don't want to enable, and in last month error message: Enginesystem need service but without DTC errors stored... and sometimes was showing me message DSTC need service ... after this repair I didn't saw dstc message almost 3 weeks...we will see...
BRAKE PEDAL POSITION SENSOR!
Just finished repair of this stuff.
Problem:1994 Volvo 850 N/A had a periodical flashing of ABS signal with ABS shutting off in unpredictable pattern. Codes were 141, 142. Tried to find the new sensor unsuccessfully. Option- replacement of the booster with the sensor. Found tread http://au.geocities.com/ozbrick850/abs-141142.html and did it. The half an hour job if you have a soldering tool handy. BTW What a poor soldering it was in a first place! Main problem is to open the plastic casing with minimal damage. Put it together and sealed with FIX ALL.
Happy volving!
Happy volving!
NothinToReport
- Year and Model: Volvo 850, 1993
If you ever neeed to translate original slovak version use this link:
http://translate.google.com
Comes in handy, many times.
Volodymyr20
- Year and Model: V70xc 2001
Hi guys, thank you all so much for being here this forum saved me a few bucks)
I am in deep confusion so asking for help
I had this message pop up on dash ENGINE SYS SERV REQUIRED after i have had a baby in hospital for 3 months and before my wife was pregnant car didnt drive a lot, i asked my dad to drive it from time to time he informed me bout that, had no time to do nothing now wife needs the car i started to figure out whats going on cant understand,now it sais URGENT but triangle is still Orange??
Now Abs and Traction light are on???
What am I looking at?
I tested the alternator it gives 13,6 -13,7 with full ac n stereo and fog lights, is it abs module or is it the SENSOR??
I NEED urgent help it refused to Start a few times in a row At All??
Is Abs blocking start???
Is sensor send some faults to abs??
Or im looking at smth else?
I rebuilt throtle body with BBA REMAN so i dont think its throtle related,
I do have a sound like grasshoppers are in my engine after i shot it down for a few seconds,???
Then a click?
But it was always like that i know?? Is it abs pump pumping by fault or error?
I never had no lights for years
That noise does sound louder but again i didnt drive it a long time
PRE STORY code on dash is 44 i dont have any power loss or function los
Speedo and odo both worked before i pulled fuse #19 than odo is black?? Nothing there blank?
Speedo works,,, should i replace Sensor or Rebuilt ABS or both both???
Please please please help
Im so broke from life have 0$ for this so every $ saved is big
Thanks everybody
Then a click?
Thanks everybody
- 5181 Views
Last post by Raindog92
- 5304 Views
Last post by precopster
- 7280 Views
Last post by zjevik
- 3835 Views
Last post by Goldchemist
- 15 Replies
- 19110 Views
