dstc service required Topic is solved
teovolvo
When I turn on the ignition key , for a couple of second I get the message "dstc service required" and after that it disappear. The dstc service seems to work fine.
- Has thanked: 2856 times
- Been thanked: 1332 times
Dynamic stability and traction control (DSTC) uses sensors to check wheel speed. If it's like the 850/S70/V70, the sensors can get gummed up with road debris and dirt and cause an error to trigger. I'd look at your problem from that angle.
Sorry, I don't know what/where the sensors are, but if you see a wire running to something around the inside of the wheel, chances are it leads to a sensor.
- 11 Replies
- 4605 Views
Last post by EngineeringBloke
- 16 Replies
- 5607 Views
Last post by precopster
- 1517 Views
Last post by grezmo
- 1290 Views
Last post by Krons
- 4580 Views
