When my ETM was failing, I noticed my cruise control wold not work properly but once the ETM was replaced it now works fine.
So does the failing ETM effect cruise?
Is cruise control effected by a failing ETM
DonWillson
- Year and Model: 2000 V70XC
Would you post more information on the symptoms of the failure and how it did not work properly. Did it hesitate and surge? Did it drop out? This information will help others identify a failing ETM.jjbeck wrote:When my ETM was failing, I noticed my cruise control wold not work properly but once the ETM was replaced it now works fine.
Thanks,
Don
Announcing my affiliation with XeMODeX, Inc. as Internet correspondent and consultant to Volvophiles needing help with failing ETMs. See http://FixYourETM.com. For the full history of this problem see http://VEXEDvolvo.org
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
Yes. Straight from VIDA is a list of what happens when the ETM detects an internal fault or the ETS (system) detects a fault in the accelerator pedal or a communication issue:jjbeck wrote:When my ETM was failing, I noticed my cruise control wold not work properly but once the ETM was replaced it now works fine.
- the accelerator pedal (AP) is ignored when braking
- the cruise control cannot be activated
- the engine speed (RPM) is limited using fuel shut off. The maximum permitted engine speed depends on the accelerator pedal (AP) position
2008 S80 T6 AWD
1999 S70 GLT
Responsible for the care of a '92 960 and an '07 S60R
1999 S70 GLT
- 3921 Views
Last post by precopster
- 13 Replies
- 3359 Views
- 5086 Views
Last post by JB3567
- 7200 Views
Last post by matthew1
- 2602 Views
Last post by nsomlai
