96 volvo miles dont count ??
solo1
Year and Model:
Post by solo1 »
my 96 volvo dont count the miles anymore ,i changed the head in the dash and still dont work , is there a sensor on the tranny? everything else works on the dash but the counter ,,any ideas guys ???
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The gears in the odometer are broken, it happens to all of them so chances are the replacement you bought had broken gears as well. It is fairly easy to fix, we have a great writeup in the database.
https://www.matthewsvolvosite.com/odometer_fix.php
Click on the Comment on this odometer fix procedure for much more information.
I buy the gears from www.odometergears.com but they are also available from IPD and FCP Groton.
solo1
Year and Model:
Post by solo1 »
thanks ill try that and keep you tosted
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
I hope that you meant.... "posted". :lol:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
solo1
Year and Model:
Post by solo1 »
yup thats it thanks guys
Post by Ozark Lee »
If you intend to correct the mileage be sure to plug the original cluster into the car. The thread indicates that the mileage is read from the ECU but that is not correct, it is stored in the instrument cluster. If you try to read it from the replacement cluster it will give you the mileage of the car that the donor part came out of.
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
The hardest part of replacing the odometer gear was getting the cluster out without messing up the dash pad. I would recommend removing the whole dash pad instead of just the drivers side and pulling up on it.
Oh, and the gears you need can be found here.
solo1
Year and Model:
Post by solo1 »
no i just did the half of the dash came out fine just dont lift it so hard ,, thanks guys
wickid54
Year and Model: '95 850 GLT
Post by wickid54 »
i'm about to repalce the gear in my odometer.
i know you can read the actual milage from the odb, but can i make the one in the dash match it?
roll it up sorta?
Post by Ozark Lee »
Scroll down toward the bottom of the page, I did a writeup on how to correct the mileage with a battery drill and a pencil.
https://www.matthewsvolvosite.com/forums ... 9&start=14
