Replacement of sideview mirror light
new99S80owner
I noticed that my driver's side review mirror courtesy light is burnt out. I want to replace the bulb, but can not figure out how to get to the bulb under the mirror. Any suggestions?
Hi
I assume you mean the drivers door mirror. The light is in a little plastic box in the bottom of the mirror unit. This little box pops out by pushing a tab 'in' on the outer edge of the light box. The tab can be prized with a small screwdriver accessed below the bottom of the glass but inside the mirror housing. Hope this helps.
Guest
Thanks for the info, AR. Good to know that you don't have to remove the whole mirror assembly.
Eli
Eli
- 3157 Views
Last post by 2002V70XC
- 894 Views
Last post by marshallh
- 13 Replies
- 6327 Views
- 1620 Views
Last post by phils94850
- 1673 Views
Last post by 850_GLT_Owner
