I can't recall if it is Permatex spark plug anti-seize I have. It is in the form of a crayon. You just rub it a little on the threads and that is all you need. Just enough to stop the interaction of the steel and aluminum with heat and time.
This isn't the one I have but similar:
https://www.agscompany.com/products/thr ... 43-oz-card
Tune up, misfire, stalling, Tune up? 1998 v70
- Has thanked: 2196 times
- Been thanked: 1850 times
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Oh ok thanks i've never used this before so had no idea.abscate wrote: 03 Dec 2022, 04:18 I use the nickel or aluminum stuff from Permatex. Just a light swipe on the threads , keep it away from the electrodes. I you hav oil in the spark plug hole you can skip it. You don’t need a torque wrench on a washered plug, just take it down until the washer hits, then about a 1/4 turn more with a 12 inch ratchet handle. Too loose is better than too tight.
One if the problems of the cool latest spark plug tip metal (Cu , then W, then Pt, then Ir) giving life up to 100k now….is that the threads are still aluminum head- steel thread. After 100k miles and 8 years of being married , your cheap spark plug bill quickly evaporates and condenses as a machine shop bill for galled threads. Of course, that’s the next owners problem, on average. I don’t even want to gon 4 years on my heavily used cars, so I stick with standard Cu electrode plugs in Volvo brand from FCP on 1-3 year intervals depending on car usage
Less is more with thread antiseize. There isn’t a lot of space in the threads so a swipe where the threads start will grease the whole thread, just 2-3 threads is fine on a plug
I just got the Permatex for the first time and was surprised at the color. It's silver. That's the color of my car so maybe i can use it to touch up some very small rust spots
- 19 Replies
- 10170 Views
Last post by Barledge
- 7659 Views
Last post by enriquepr21
- 1615 Views
Last post by mika
- 18 Replies
- 3635 Views
- 1637 Views
Last post by AD_NAPCO
