Hi,wizechatmgr wrote: 12 Feb 2023, 21:27 Did you figure out what was drawing the battery down to begin with? Is it just a case of not using the car as regularly as it may like?
I think what it really is is that the car isnt driven that much combined with the way they designed the charging system and maybe the battery type.
For one thing what happens is the battery does not charge that well at the alternator design point of exactly 14.00 volts. It needs 14.2 or maybe even 14.5v like some cars have.
It could be because the car is not driven that much so the battery does not get charged as well as if it was driven every day. That makes the battery eventually get even less charged as time goes on because it appears that the battery internal resistance goes up a little and that prevents the alternator from charging the battery as much as it can if the battery was new.
If the charge voltage was more like 14.5v it would charge every time just going to the store and back. That's why i considered adding the 'boost' diode to the voltage regulator. This is an easy mod if you can get your voltage regulator out of the car, but that's something i have not been able to do yet. The alternator is buried in the engine compartment pretty deep, and although i have read it is possible it seems quite hard to do. For one, have to drain some of the radiator fluid.
This is also something that many people have noticed now as i look around the web. I first considered this way back in the 1990's as my Hyundai developed the same problem. I could have done it with that one though the alternator was easy to get out.
The fix is easy, you just have to break the ground connection to the voltage regualtor and insert two diodes connected back to back (antiparallel) and the voltage goes up by about 0.5 volts (Schottky diodes). The diodes are ultra cheap 20 for $5 USD. It fools the voltage regulator into thinking the battery voltage is lower than it really is, so it raises the charging voltage.
So right now i am working on the solar panel solution and i can see that it should work with a few changes.
I'll update when i get more done on it, hopefully today or tomorrow depending on weather.
