Transmission fluid leak?
5rivers
Year and Model: V70 1998 T5
Been thanked: 14 times
Re: Transmission fluid leak?
Post by 5rivers »
The cover that is still leaking transmission fluid is called a "protecting casing" part number 6843815 found on automatic 850's '93-95, '96 - , plus my '98 V70 T5 auto. Still looking for one!!
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 22 times
Post by greg850r »
If it's rusted through, the whole sheet metal cover is thin. Fix one hole and another appears from messing with it. It's a small part, Just bolt on another. I can send you one if you can't find one closer. No difference between a solid used one and new.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
5rivers
Post by 5rivers »
Thanks, greg850r! I'll get back to you in a few weeks if I have not found one nearby!
5rivers
SOURDOUGHJIM
Year and Model: 2004 V70 2.4
Has thanked: 53 times
Been thanked: 27 times
Post by SOURDOUGHJIM »
I had a fuel tank repaired at a radiator shop. A sheet metal patch soldered onto the tank at the rust site. Might be an option here.
5rivers
Post by 5rivers »
I found a used cover!!
Now, the question is what kind of gasket material can I use? The material that oozzed out on the sides of the cover before taking it off the donor vehicle was orange in color.
I have some of the anaerobic redish/pink material left over from doing the cylinder head/oil pan cover on the blue V70, can I use that on this cover?
AND...
The bolts that came off were covered with the gasket material - I will clean those off and apply new.
Other than making sure the bolts are on tight, are there torque specs I need to be aware of?
Appreciate your replies!
5rivers
Has thanked: 1506 times
Been thanked: 3822 times
That pink anerobic is for joining two machine matched surfaces , not sealing a metal to metal dissimilar junction. I’m not sure what is used there, let the Collective Hive share its wisdom
