And remember, you are running standard brakes! Abscates car brakes were doing double duty so down hills you could induce brake fade/overheating. Almost safer using a light alloy trailer with it's own brakes.
2000 Volvo S70 Towing Capacity
- Has thanked: 2210 times
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
You’d probably be fine with the Curt for that. I personally don’t really trust it, but for something that light, you should be able to get away with ittjmartin317 wrote: 28 Aug 2023, 18:43Wouldn't even be a full type 3, just the shell of one:
A few guys could lift that onto a trailer no problem... but I don't have a Volvo trailer hitch, which leaves my options to Curt and whatever Uhaul may install...
EDIT: Looks like Uhaul will sell and install a Curt trailer receiver... rated for 3500lbs, but again, it doesn't sound like some folks on here trust it.
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Please note that while you may technically be able to pull that much, stopping it is where people often find the issue. Be careful =)
2023 Lexus RZ450e -66k
- Has thanked: 1611 times
- Been thanked: 4075 times
Keep it under 60 and triple your following distances. That Tyoe 3 shell will be under 1000 pounds , that tow will be fine
- V50M66
This. I'd highly recommend upgrading to 302mm brakes and good pads before heavier towing. You never know when some idiot will cut you off, even if you adhere to large following distanceswizechatmgr wrote: 29 Aug 2023, 23:04 Please note that while you may technically be able to pull that much, stopping it is where people often find the issue. Be careful =)
It’s hills that are the killer. You won’t fade a280 mm brake with any single stop.
I just put an egg crate grill on the yard vehicle, that keeps the speed down
surfbug1
- Year and Model: 1998 V70, 2006 S80
- Has thanked: 41 times
- Been thanked: 9 times
abscate wrote: 28 Aug 2023, 17:43 An air cooled type 3 weighs under 2000 pounds. You could dolly that nice and slow, but stop every 2-3 hours and let things cool off. With an M56, you don’t have to worry about ATF temperature!
I just trailered a 3500 pound v70 with an NA V70 and it was near the limit of safe , power wise. Look at my coolant temps….
where didja get that app?
very slick
yes I towed an RV that was 35-3800lbs with a v70 turbo
go slow.....no issues!
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
Ping me!
OBDLink with the OBDLink MX+ scanner, about $100 all insurfbug1 wrote: 02 Sep 2023, 02:35abscate wrote: 28 Aug 2023, 17:43 An air cooled type 3 weighs under 2000 pounds. You could dolly that nice and slow, but stop every 2-3 hours and let things cool off. With an M56, you don’t have to worry about ATF temperature!
very slick
Codes, fuel trims, and most PIDS but no Volvo codes. It fits into my travel bag so I always have a reachable scanner in any car I drive, useful in my battered fleet
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
If you're renting a Uhaul rig, it should have surge brakes; with that little bit of weight you'll be fine. Be sensible about tongue weight; if you balance the shell so you end up with ca. 200 pounds on the tongue - about 10-15% of the total rig - then none of that should put any heroic strain on brakes or stock springs. Think about it in light aircraft terms; if you have a full tank of gas, vacation load in the trunk, and four American sized humans in the car, what does that weigh ?tjmartin317 wrote: 28 Aug 2023, 18:43Wouldn't even be a full type 3, just the shell of one:
Do the sawhorses convey ? Extra ten pounds there.
You can spring for the carbon fiber ones to keep the load down.
Everything I trailer , I take up ftom 50 mph in 5 mph steps and look for the telltale swaying of the towed load. If you see that , keep your speed 5 mph below that. Watch for Rolling over speed
Coming down hills
Coming down hills
- 3665 Views
- 3287 Views
Last post by bmdubya1198
- 1637 Views
Last post by Rattnalle
- 591 Views
Last post by Ozark Lee
- 1185 Views
Last post by jimmy57
