Heat Help
No it's the temperature that's the problem at all vents. It's either ice cold or warm. I'm thinking the one which regulates temperature (not fully switching air flow to the heater core) but don't know which one that is or where it's located. Thanks in advance.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 481 times
did you look at the ambient temp sensor?
located in the bottom of the driver side mirror.
door inside panel can be removed to inspect the harness, the usual suspect.
- Been thanked: 472 times
Heat problem in the P2 cars boils down to:
1. HVAC linkage arm.
Just kneel down and look if the linkage arm moves when
the setting is changed from Blue to Red (key in position II).
2. Thermostat is usually suboptimal at 100K miles.
Temp gauge showing 12:00 position does not necessarily mean the coolant temp is correct.
I use Wahler.
I hear Facet brand is good too.
3. Heater Core:
Behr is good.
4. WP impeller rarely rarely breaks off, unless it was replaced with an aftermarket, non-Aisin item.
All info is in this forum.
I use Wahler.
3. Heater Core:
Behr is good.
- 339 Views
Last post by Flyingdutchman
- 1163 Views
Last post by coldax
