737 MAX-9 preliminary report
Forum rules
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Juan is pretty well-positioned to make these videos; he's a veteran Air Force 'Mishap' investigator and instructor, a current 777 pilot, and a licensed Airframe & Powerplant certificate holder.
This is the third in sequence as he notes.
foggydogg
Post by foggydogg »
BlackBart wrote: 09 Jan 2024, 11:51 Juan Brown -
He lost an engine during a night flight from Hawaii to LA, and said the final 2 hours of that flight was the longest five years of his life. Stuck the single-engine landing at LAX, right on the first hashmarks.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
matthew1 wrote: 09 Jan 2024, 14:03
Max. take-off weight: ~ 89,765kg
BlackBart
Post by BlackBart »
I have read that those splayed wingtip pieces are made by Pocock in the Seattle area. Pocock is the Seattle company that built all the beautiful cedar / mahogany rowing / crew shells for the University of Washington and others, which gave way to super lightweight carbon fiber rowing shells that were world class and appeared in the Olympics regularly, which led to being an expert carbon fiber engineering firm.
If you go watch The Boys in the Boat movie, those are Pocock shells that beat the nazis. That boat that those boys rowed to the gold medal is displayed overhead in the U of Washington crew house.
https://www.pocock.com
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
abscate wrote: 09 Jan 2024, 10:23 You guys realize these things pressure test like an P0455 evap code? I just learned that from retired Boeing brother
Everyone knows you just reset P0455 codes and move on.
volvolugnutr
Has thanked: 1609 times
Been thanked: 4064 times
I think they were also worried when the plug popped out, people would read the sign on the engine…..
This is looking bad for Boeing….UA is finding loose bolts on their Max-9s…someone forgot the torque wrench and the Loctite…
From Juan’s video, the plugs get put in at Wichita, but get removed and reinstalled in Renton when the fuse is fitted out for end customer.
BlackBart
Post by BlackBart »
Right - the last person who touched it was Boeing Renton.
I don’t get where the seal is. The “sheet metal” skin is flush with the fuselage skin and there has to be a tiny panel gap to fit it.
You don’t have to seal it that tightly. Pressure differential is only 8 psi or so
Bad humor time
Boeing renamed “ Bolting”
We serve hot nuts , make sure they aren’t metal
foggydogg
Post by foggydogg »
The last time Boeing made a profit was 2018.
More deep diving with Juan.
Note his correction about the door plug as received from Spirit.
Interesting picture of the wifi installation being done by "Others."
Sounds like the -9s are going to be grounded for a while.
BlackBart
Post by BlackBart »
Ah, so Spirit did the final bolting of that door.
I always learn a lot from his pieces.
