1999 V70 NA part out, location Long Island NY ( Good engine , transmission pulled, available 10/2024)
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Re: 1999 V70 NA part out, location Long Island NY
Post by MoVolvos »
Does it share the same rear axles with our 00 S70 SE NA and if so is there still a possibility of a road trip out this way?
Has thanked: 1843 times
Been thanked: 1710 times
Rear axles? Is the S70 NA not FWD?
Has thanked: 1502 times
Been thanked: 3817 times
Itis a FWD car
It’s also a non sun roof edition Base model
Pulled the drive axles and all calipers off today, muffler, cat,
I’ll pull the emissions package as that’s all new too
I’m going to scrap the engine and trans, and pull the brand new cylinder head.
MoVolvos
Post by MoVolvos »
abscate wrote: 21 Sep 2024, 19:19 Pulled the drive axles and all calipers off today, muffler, cat,
The trailing arms have a greater application than when I first researched. Same for other side.
Positions: RIGHT Other Names: Support Arm, Support Arm R
Description: S70, V70. Right. Without awd.
Applications: 2WD - C70, S70, V70 (1998-04)
https://www.volvocarsoempartsdirect.com ... dhcw%3D%3D
MoVolvos
Post by MoVolvos »
scot850 wrote: 06 Jun 2024, 19:52 Rear axles? Is the S70 NA not FWD?
Little late to the party but I meant rear trailing arms and yes NA are FWD.
MarinerMan
Year and Model: 1999 V70 N/A
Been thanked: 6 times
Post by MarinerMan »
You didn't happen to harvest the clockspring out of this did you? I have been trying to get my hands on one as a just in case mine fails.
I have it but Sean in RI has first dibs
MoVolvos wrote: 21 Sep 2024, 20:41
I have two trailing arms off a 2000 up in Albany , and a trip to Raleigh scheduled on Oct 14
Could get scrubbed by weather but will be postponed , not cancelled.
MoVolvos
Post by MoVolvos »
abscate wrote: 01 Oct 2024, 06:45
It would be great if you could bring both for our 2000 S70 :!: :?: From the damage do you think I need any other parts? Heavy positive camber from hitting the center medium.
