I always break loose bleeder screws with a standard six point deep socket. That way you grip all six sides at once not just four, and can apply clean axial force.
Then I move to a flare nut wrench to open and close the screw for the actual bleed process.
Can you tap on a slightly smaller six point socket?
Brake line question
- Has thanked: 311 times
- Been thanked: 817 times
lcc014
- Year and Model: 855, 1995
- Has thanked: 2 times
- Been thanked: 11 times
That was exactly what I used - craftsman 11mm flare nut wrench and it rounded the fitting nut in the very first try. I will get a couple Snapon flare nut wrench, 9mm, 10mm, 11mm and 12mm, just in case.Clemens wrote: 30 Jul 2024, 16:30 file the fitting down to the next SAE size. If that doesn't work, file down to 10mm. Ask me how I know ...
And a high quality like Snapon flare nut wrench pays off. My craftsman 11mm slipped (yes, they are 11mm), but the next smaller snapon plus a few heat cycles did the trick
lcc014
This was not the bleeder screw, it was the caliper-brake line fitting nut. No way to use a six points socket unless I cut the brake line to the fitting.erikv11 wrote: 30 Jul 2024, 21:39 I always break loose bleeder screws with a standard six point deep socket. That way you grip all six sides at once not just four, and can apply clean axial force.
Oops - My mistake I should pay closer attention! Thanks for explaining.lcc014 wrote: 31 Jul 2024, 05:39This was not the bleeder screw, it was the caliper-brake line fitting nut. No way to use a six points socket unless I cut the brake line to the fitting.erikv11 wrote: 30 Jul 2024, 21:39 I always break loose bleeder screws with a standard six point deep socket. That way you grip all six sides at once not just four, and can apply clean axial force.
lcc014
erikv11 wrote: 31 Jul 2024, 16:42Oops - My mistake I should pay closer attention! Thanks for explaining.lcc014 wrote: 31 Jul 2024, 05:39This was not the bleeder screw, it was the caliper-brake line fitting nut. No way to use a six points socket unless I cut the brake line to the fitting.erikv11 wrote: 30 Jul 2024, 21:39 I always break loose bleeder screws with a standard six point deep socket. That way you grip all six sides at once not just four, and can apply clean axial force.
