97 Volvo 850 turbo no crank [ bad starter 10 years old Delco] Topic is solved
Vova585
Year and Model: 01v70xc,2016xc70...
Has thanked: 228 times
Been thanked: 238 times
Post by Vova585 »
Dcarson, please look at the previously attached wiring diagram. It will show green wire at the post 50 of the starter. On your picture you can see smaller green wire. Trace it to the connector at the starter and it will be your "s" terminal. Reread post from Lee Ozark that I included and find service starter wire to which you will be able to apply 12v as described in that post.
dcarlson12
Year and Model: 1997 850 T5
Been thanked: 2 times
Post by dcarlson12 »
I had my wife turn the ignition switch to the start position and used a test light to determine that 12 volts was reaching the 's' terminal of the solenoid. i.e. the solenoid appears to be toast.
Thanks for everyone's help.
I looked in my log book and see that I installed a 'new' AC Delco starter back in July of 2015. It supposedly has a lifetime warranty but I can't seen to find the receipt so I might be sweet out of luck. I got it from Lordco in South Surrey, BC.
Has thanked: 1610 times
Been thanked: 4065 times
Pretty decent service life for an aftermarket part, duly noted and marked.
I started using the maintenance pages here to log my receipts for stuff ftom FCP by order number , and tires amd batteries
