Replaced front O2, immediate misfires, high trim. Diagnostic help? Topic is solved
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Vova585
Year and Model: 01v70xc,2016xc70...
Has thanked: 155 times
Been thanked: 142 times
Re: Replaced front O2, immediate misfires, high trim. Diagnostic help?
Post by Vova585 »
vtl wrote: 06 Apr 2025, 18:39
Vova585 wrote: 06 Apr 2025, 18:37 If you want to try it yourself get this one.
https://www.amazon.com/dp/B0BSH2XS4R?li ... ics_f_asin
$69 https://www.amazon.com/dp/B07JVT1NG2 I have this one, it works.
Does that one require to have external air compressor and pressure regulator? I like the one above since it had built in pump and can be portable. Sure not as much "smoke" delivery as OTC or harbor freight icon or the one vtl suggested, but has its benefits depending on shop equipment and work setting
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Vova585 wrote: 06 Apr 2025, 18:46 Does that one require to have external air compressor and pressure regulator? I like the one above since it had built in pump and can be portable. Sure not as much "smoke" delivery as OTC or harbor freight icon or the one vtl suggested, but has its benefits depending on shop equipment and work setting
Yes. I have two compressors ;)
leapdragon
Year and Model: 2007 XC70
Has thanked: 12 times
Been thanked: 31 times
Post by leapdragon »
Still toying with whether I want to do this myself or not. Somehow timing belts and CV axles and PCV service and quick struts intimidate me less than wiring harnesses and vacuum leaks.
But I do think it makes sense to get ahold of a no compressor smoke tester (I don't have a compressor either, my impact wrenches are all electric). I have ALMOST done it several times.
Meanwhile, I dragged the VIDA laptop back out and hooked it up to see if there was anything there that's not there with a regular scanner. To be honest I sort of hate using VIDA, it's ugly and slow and unpredictable. At first I FREAKED OUT at the list of codes lighting up like a Christmas tree but then I remembered that yellow = past code and that:
- Head unit was replaced with aftermarket
- Thus parking assist and AUM are angry because head unit is missing
- Since I last scanned I have remedied door latches, tailgate latches, child locking system, other items
So once I calmed down the only one that stands out is orange/current: ECM-121D, MAF signal too low
It seems incredibly unlikely that somehow my MAF decided to die exactly when i replaced the front O2 A/F sensor. But would a vacuum leak somehow cause the car to decide to throw an MAF code? Car was driving perfectly before I decided to do this preventative sensor replacement and I had no codes and average fuel economy, so I doubt the MAF has been bad all along...
Any thoughts about how the MAF code plays into all of this?
vtl
Post by vtl »
That's exactly how vacuum leak shows itself up: MAF starts to read less air than really enters the engine (and the engine knows it).
leapdragon
Ah! So this is just P0101. Got it.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
I used this mnual; transfer pump, stick a cigarette in the top inlet, connect the bottom outlet to the intake manifold and start pumping.
https://www.amazon.com/HORUSDY-Multi-Us ... 168&sr=8-6
Vova585
Post by Vova585 »
jonesg wrote: 06 Apr 2025, 19:55 I used this mnual; transfer pump, stick a cigarette in the top inlet, connect the bottom outlet to the intake manifold and start pumping.
Well I see problem with that. You will have to buy a pack of cigarettes and maybe use 2-3...then you will find the leak and will decide to celebrate it with a cold beer...and then you discover that you have 17 unused cigarettes...for some of us who quit it might be a tough challenge
leapdragon
Ordered smoke tester, should be here tomorrow afternoon.
Questions for all:
- Any thoughts on best place/port to inject "smoke"?
- Also, how concerned should I be about fouling the MAF sensor by blowing "smoke" into the turbo inlet pipe?
- Possible that my tightening the O2 sensor actually cracked the exhaust manifold loose or something and that's where the air is coming from?
The thing that keeps me confused is that the little things don't match here.
- Stepping on the throttle didn't cause the running to smooth out, it led to misfire codes
- Also, when stepping on the throttle, the short-term fuel trim stayed pegged to max
I would expect that for any non-obvious vacuum leak, adding throttle would smooth it out, and also cause short terms to fall at least a little, yet here we are and I've had eyes and hands all over all that stuff and can't see where the leak might be.
Any other brainstorms while I wait for smoke tester?
vtl
Post by vtl »
vtl
Post by vtl »
Do a throttle swipe test, since you have VIDA. Bosch is not known for premature death, but still can happen.
