Update: I repeated the timing process. In addition to the locking of the camshafts, I also locked the crankshaft with the specialized tool. The time markings were not off, however, I have measure the angle difference between intake and exhaust camshaft, and detected 3.5 degrees difference (not sure whether this is something related with the VVT play). I meticulously torqued the VVT sprockets (it seem I have over torqued these the first time). I also replaced again the camshaft position sensor giving the signal with a japanese OE. The ProPartsSweden I put was not locking the connector after I push it in place.
Overall, the engine light is gone by it self. No need of erasing the light with the scanner. I will be testing the car and hope the light is not coming back.
XC70 throw ECM-671C after replacing camshaft position sensor
amolero
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 2 times
It is quite possible. However, I cannot rule out some minimal mistiming.Vova585 wrote: 22 May 2025, 14:46 So moral of the story-electronic parts from PPS are junk that were costing you at least 10 hours and a full "swear jar".
I also had a bad experience no far ago with the VVT solenoid. I replace the failing one with a febi bilstein, and the check engine light keep coming sporadically. Then, I replaced the FB solenoid with an original Volvo, and no more engine codes.
I am learning the hard way. Next time, only original parts.
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
[/quote]
I have nobproblem using some aftermarket mechanical part(radiator-nissens, steering shaft-PPS(made in Sweden and has all the same marking as oem, brakes- textar, akebono, bosch...) but with anything that related to electronics I think we are way better with used oem vs new oem(if available/able to afford)
[/quote]
- 1370 Views
Last post by volvolugnut
- 5193 Views
- 2523 Views
Last post by Labone
- 6836 Views
Last post by prwood
- 3800 Views
Last post by PixelDust
