2006 S60 2.5T AWD Parking Brake? Problem Topic is solved
SacredHeart
Year and Model: 2006 S60 2.5T AWD
Has thanked: 12 times
Been thanked: 2 times
Post by SacredHeart »
Ultimately the pads separated from the shoes on the parking brakes. I am not sure if that was the exact issue that prevented the car from backing up, but it was the only thing that they could find. I had the shoes replaced and a rear brake job done. Thanks for the help on this.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
jonesg wrote: 28 May 2025, 17:23 Heres how it went for me, I figured its a 90 minute job.
Jack the car up, forgot to break the lug bolts loose, lower the car again, got the bolts loose, jack the car up, place on jackstands, the wheel won't come off.
Lower the car again and put the lugs in finger tight, drive the car back and forth a couple of feet to break the wheel loose from the hub.
Jack the car up again and remove the wheel.
Remove the caliper and hang from a coathanger.
Brake disk won't come off, fight with it. eventually popped off, hammers pry bars etc.
Brake shoe falls out in bits.
Order or go pick up new shoes.
Springs are shot, get brake kit.
Get the new shoes in place, its easy, just need to wipe the blood up from the shoe.
Everything back in place, emergency brake still won't lock car in place, I know it will fail inspection.
Tightened the Ebrake cable at the lever, and....the cable adjuster broke.
Ordered new cables and adjuster. around $140 , I forget. Old cables were stretched out.
Still no bite on the new shoes, removed and compared to the original volvo shoes, very slight difference, I cleaned the paint off the shoe backplate slots with a file to make it fit the H spacer bar a bit easier, now it works better.
Sprayed the shoes and brake disk surface with brake kleen, installed wheel and set parking brake loose, drove it 100 yards to mate the surfaces.
Yours should go easier.
Took me over a week, thats why the mechanics make the money.
You forgot a step in the middle. The little hole/brackets on the rear dust shields completely rotting away and you need to install new dust shields. That's when I threw in the towel and deleted my parking brakes.
04s60 2.4
04xc70 2.5t
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
br0dy519 wrote: 24 Jun 2025, 13:30 You forgot a step in the middle. The little hole/brackets on the rear dust shields completely rotting away and you need to install new dust shields. That's when I threw in the towel and deleted my parking brakes.
that happened on the front dust shields, I used fender washers and they've held up for 8 yrs.
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 66 times
Been thanked: 92 times
Post by DavidE7 »
Also don't forget to put a thin coating of anti-seize on the hub where the aluminium touches so the wheel is easy to remove next time.
I did a rear parking brake pads, spring hardware, disks, and hydraulic brake pads replacement on the 2001 Blue V70 a couple weekends ago and then found that one of the two parking brake cables was sticking. One cable was bad and the other was fine. I could only see that pulling on the lever wouldn't lock the tire with the sticking cable. The cable still moved a little but it wouldn't expand the pads fully and it wouldn't retract completely. I replaced the bad cable and the system worked so well that I can now skid the rear tires by pulling on the lever firmly. The VIDA instructions are good for replacing the cable. Tie a rope onto the old cable before removing it so you can pull the replacement cable into position without having to remove the rear carpet.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
