If you aren’t removing the VVT Hub , you don’t need the cam lock tool. Set the crank to the timing mark ( not TDC), set cam gears to the marks with them clocked clockwise ( exhaust only on your 1999, the intake is a hard gear)
Install belt , then turn it over a full revolution. Check marks.
It’s tight tolerance, one tooth only, to keep the P0014 code off
1999 S70 - Water Pump, Timing Belt - P0014
- Been thanked: 4069 times
- Has thanked: 2205 times
Is the car a non-turbo or turbo? I may have missed the details I have read, but I can't see it mentioned. NA/non-turbo is an intake CVVT solenoid, Turbo is an exhaust CVVT solenoid if a 1999 is the same as a 2000.
He’s a turbo. If you look at the pix he is exhaust VVT.
- 32 Replies
- 8436 Views
Last post by SoCalV70T5
- 22 Replies
- 35992 Views
Last post by erikv11
- 36 Replies
- 2431 Views
Last post by ericmci
- 1034 Views
Last post by cn90
- 1595 Views
Last post by geego1
