My thoughts exactly - I haven’t bothered to check the length of wire but I was able to remove the sensor and clean it up but reinstalled it is still giving the same error code. The sensor looks original so at this point I’m just going to order a new set and go ahead and replace both of them. Maybe I’ll find something on removal.Vova585 wrote: 27 Jul 2025, 09:28
If you changed input from RR to LR inside the connector and issue moved to LR- your issue is actual sensor or a wire assembly.
S70 Tracs/ABS problem Topic is solved
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
RonMac
- Year and Model: 1998 S70
- Has thanked: 10 times
- Been thanked: 4 times
• Wheel Sensor Fault:
This fault emerged a few years after I had successfully repaired the ABS module on my 1998 S70. So I replaced one of the front wheel sensors with a new one and also spliced in fresh wiring where flexing may cause more stress. Despite this the same fault code persisted.
• ABS Module:
So, although years previously I had re-soldered the commonly reported, faulty joints inside the ABS module, I decided to revisit the repair. On the second tear-down, I targeted and re-soldered a different set of joints—specifically those associated with the wheel sensor input, as flagged by the fault code. This instantly and permanently fixed the new wheel sensor issue.
If your re-manufactured ABS module was only repaired at the usual suspect joints, I wouldn’t rule it out as the source of the ongoing fault. It may still require further attention—particularly re-soldering of additional dry or defective joints. From what I understand, the original ABS modules manufactured in the Philippines suffered from insufficient heating during soldering, which contributed to latent circuit board issues that manifest years later.
BTW, I have spare, front & rear, new wheel sensors that I no longer need. (they rarely fail).
• ABS Module:
shegarty
I ended up replacing both rear wheel speed sensors as they come as a pair in one harness. The rebuilt unit was a XEMODEX unit and they have a pretty good reputation and warranty so I figured it probably wasn’t a fault in their work. Seems to be pretty good so far, it’s been about a week or so now.
- 22 Replies
- 5838 Views
Last post by hausmeister
- 1818 Views
Last post by Matty Moo
- 1504 Views
Last post by JRev
1999 S70 ABS/TRACS light on after resolder
by jlferreira » » in 850, S70, V70, C70, V70-XC 1992-2000 - 1 Replies
- 800 Views
Last post by jose456891
- 19 Replies
- 5033 Views
Last post by theWIFES_S70
