unobtainium? What 850 parts are getting hard to find?
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
There is a thread here somewhere on junkyard parts that should not be left behind. Someone with better search skills will have to post the link, but that would give you an idea as to what to start hoarding.
1999 V70 GLT
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
Welcome to MVS, 850turbo95. That's a beauty wagon. Outstanding find.
I renamed your thread to get more responses.
You can look through this search search.php?keywords=nla&terms=all&autho ... mit=Search for what's hard to find, or impossible. It doesn't answer your question, but gives a rough idea of what's toast and what's soon toast (bread?).
Also -> Amazon link
Has thanked: 1610 times
Been thanked: 4071 times
There was a wierd adjustable intake runner option in 1993 that , if you have it, don’t be easy to fix. It might not be on turbos.
Turbos on these cars don’t break, especially at 93k miles. Nothing really breaks on these cars at 100k miles. Use a high grade synthetic oil and Volvo filters
Treat it as a run to fail vehicle for the next 50k miles, replacing parts as they go for best cost of ownership.
Glove test for Pcv
Compression test for motor
Check oil consumption for stem seal problems
Turbo exhaust valves no longer available so don’t let a burned valve happen to you.
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 29 times
Post by RedBrickCollector »
Unobtanium? Interior parts, especially the plastics that tend to break like anything to do with the dashboard, the door pull cups, the wagon cargo cover. Exterior rubber parts like door seals, roof rail gaskets are now very hit or miss.
Fuel pressure regulator isn't quite unobtanium but it's gotten more difficult.
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
