Oil leaking on 2004 volvo c70 LPT
TJsPOV
Year and Model: 2004 c70 2.4T
Been thanked: 4 times
Post by TJsPOV »
@ CIK7 this is exactly what I saw sometime back when I was changing the plugs. I never realized it was that and thought maybe it was in error from the prior owner.
Once I finished plugs I watched for oil and saw some more going up. Bought a new cap today and through it on. havent seen any more oil after cleanig it all above and below with brake cleaner.
will still look and monitor .
@vova - I did exactly this, all seems good. will update you guys tomorrow once i drive it further for work. always appreciative of the responses I get here!
Has thanked: 1613 times
Been thanked: 4078 times
TJsPOV wrote: 25 Nov 2025, 16:04 think its still possible for the cam seals to leak if they were replaced within a year and less than like 6k miles?
ill check the crankshaft seal now
It is a job you can screw up three ways..
1. Bad cheap part. Volvo or Corteco only
2 incorrect seating depth into head
3 neglecting VVT wear which will not seal on the new seal
Number 1 is most likely, if the parts come from eBay, AZ, or the jungle they are probably junk.
