Need a rack and pinion 96 855t Topic is solved
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
scot850 wrote: 26 May 2026, 08:42 Thanks for letting us know about this brand Chuck. Interesting that they list the FWD and AWD with different racks. Are they different?
I don't *think* so, but I'm not familiar with the AWD cars.
The info is based reports from people who have installed them, one of who track drives their car. It's a route I'll probably investigate if/when we need another.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
I think I'd "steer" (har har) away from Detroit Axle. My son is shipping one back for a refund as I type this.
Granted it was for a Jeep, but It's still worth mentioning. The shop that was doing the work said that the rack was clocked completely off, and that this wasn't the first Detroit unit that they had this problem with.
1999 V70 GLT
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
Helpful review. My steering is seriously notchy, pulsates and whines loudly. My brilliant idea of replacing the ps pump with my low miles oem spare made things worse. It only leaks a tiny amount from the drivers side outer boot. Maybe Rock Auto pump is the way to go. Car is way to nice for the boneyard. I have the rounded cap on the end of the pinion and it's an oem rebuild from Jorgen a few years back. The AWD racks have a bracket that is different but I believe otherwise the same and bracket can be modified either way. Thanks for all the updates.
Has thanked: 1611 times
Been thanked: 4075 times
They are listed as different in the Volvo parts online engine. Chassis breaks too, on the xc70 at least
Maybe just mounting?
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
AWD rack is different from the FWD racks - the FWD rack has a provision for the rear engine mount, and the AWD rack doesn't due to a difference in engine mount position to make room for the angle gear.
You can turn a FWD rack into an AWD rack by cutting off the mounting boss for the engine mount. They are the same otherwise.
SMI vs TRW doesn't matter, they're compatible with each other and the only functional difference is the inner tie rods use a different thread on the rack side.
Avoid Detroit Axle, Cardone, Maval, and any other rebuilt rack. They are all junk. Leak fluid almost immediately and even lock up while driving in a few cases.
You want an AAE 3095N off RockAuto. They're brand new out of a factory in China - the Europeans have been using them for years without issue, and I've yet to see a report of a failed one in the US. Have one in my Emerald '98 and it's been great. If you have an AWD car, buy this rack and cut the mounting boss off. This is the only rack you should buy.
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
rguzz
Post by rguzz »
Thanks, I will order rock auto AAE replacement and go from there, tie rods TRW as mine are shot and using them again seems foolish. Nice thread summarizes a lot for me.
V50M66
Post by V50M66 »
AAE rack comes with new inners and boots, though it probably doesn't hurt to get something better quality if you wanted. They're TRW style. Mine are still tight at 12k though so up to you
rguzz
Post by rguzz »
AAE rack is in and functioning. Still a whine from the pump but much better and that's all the symptoms, steers and drives fine. So, success!
