Yes, absolutely. But MBCs can also control it. The game is won or lost in controlling not just max boost, but boost-at-any-given-RPM. You don't want boost to come on too early. I'll try to note what PSI my 850 is at at say 2000 RPM, for reference.
Fast Fridays have lots of information about boost:
Fast Friday#12: Turbos and Exhaust
"... but first let’s understand why the larger turbos in the TD04 family can be prone to boost spike or rapid early RPM boost development."
Fast Friday #4: The Boost Variance Problem
"The BPS in these models is more for control of max boost target (I.E. over boost or spiking) rather than as a feedback..."
Fast Friday #3: Lucky talks Chip vs. MBC
"... If your intention is to use the MBC to control spikes then you have it setup correctly."
Lucky has forgotten more about this than I'll ever know, so take what I say with a grain of salt.
Recomended MBC for Volvo 850 Turbo
- Has thanked: 2856 times
- Been thanked: 1332 times
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
Any thoughts on an electronic boost controller? Boost gauge, boost controller and a new TCV to boot:
http://www.ebay.com/itm/2012-new-HDi-el ... 71&vxp=mtr
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
I'm considering one of these. You can find them on Amazon for less than $30 so I'll probably order from there.
These seem to work well (something as simple as an MBC should) from what I've seen on other forums.
http://www.zenboost.com/boost_controlle ... oo_IV_MBC/
https://www.amazon.com/s?ie=UTF8&page=1& ... odoo%20MBC
I'm a big fan of MBCs. Watch that boost!
boosted5cyl
What initiates the fuel cutoff? ECU sees airflow outside normal range and cuts the juice?matthew1 wrote: I do not get fuel cutoff until ~90mph / full throttle.
No idea, but that'd be my guess.
Jimmy? JDS60R?
Jimmy? JDS60R?
I should clarify my sentence from a couple months ago:
CORRECT:
I do not get fuel cutoff until ~90mph@full throttle.
Without the @ symbol it makes my sentence read like fuel cutoff happens at ~90mph OR full throttle, which is incorrect. It's ~90mph@WOT.
CORRECT:
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Mot 4.3 and 4.4 use MAF vs RPM and a factor to decide when to shut down for inferred overboost.
I'm not sure if that is an answer you're looking for as there isn't a road speed shut down on the 97 until 155mph.
If you are over boosting then 90 MPH may be where you get enough load to have an overboost where the air consumption goes off the allowed map.
BTW, you'll go off the map more readily at lower altitude and in colder air temps. THe MAF signal goes higher with denser air.
97_boostedgLt
- Year and Model: 850 Glt 1997
Look at Turbosmart "T" MBC (89.95) wanna spend the momey on a MBC if u cant afford a EBC. That said, running the T MBC with ARD white tune, at 12lbs 253 HP, on my 1997 Volvo 850 GLT, Absolutley STOUT and made the car a whole new animal.been about a month and no spike in boost, doesnt boost to high in low rpms. All u need is a proper tune and a MBC is the quickest and easiest way to up your HP, Tq, etc.
hope this helps!
hope this helps!
epukerob
- Year and Model: C70 1999, S80 2003
"...doesnt boost to high in low rpms." Do you mean low GEARS? And if so, how is the MBC "bypassed" in the low gears??97_boostedgLt wrote:Look at Turbosmart "T" MBC (89.95) wanna spend the momey on a MBC if u cant afford a EBC. That said, running the T MBC with ARD white tune, at 12lbs 253 HP, on my 1997 Volvo 850 GLT, Absolutley STOUT and made the car a whole new animal.been about a month and no spike in boost, doesnt boost to high in low rpms. All u need is a proper tune and a MBC is the quickest and easiest way to up your HP, Tq, etc.
hope this helps!
- 2689 Views
Last post by matthew1
- 525 Views
Last post by erikv11
- 1094 Views
Last post by Rocketman96
- 1821 Views
Last post by jimmy57
- 1140 Views
Last post by JimBee
