Front Suspension - Spring noise - 2001 V70 2.4T
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
No picture...looks like you have to be a paying member to see the pics over on Volvospeed. Why not use ImageShack and post again on this forum?
Harleyvh
Year and Model: 2011 S60 T6 AWD
Post by Harleyvh »
Sorry about this one.
New to process
Posted the images on Imageshack
Driver side:
http://img88.imageshack.us/img88/3253/driver3av5.jpg
ttp://img88.imageshack.us/my.php?image=driver2hk6.jpg
Passenger Side - Noise Side:
http://img88.imageshack.us/my.php?image ... er3wt9.jpg
http://img88.imageshack.us/img88/3848/passenger1wq8.jpg
Hope it works.
2001 V70 2.4T - RIP
2011 S60 T6 AWD - In progress
2004 V40 - "backup"
Harleyvh
Post by Harleyvh »
Quick update:
I checked my albums on volvospeed.
The "suspension" album was not public.
Rectified situation.
2001 V70 2.4T - RIP
2004 V40 - "backup"
The pictures look fine. It is so hard to tell from them. I will tell you that on my cars I can't see the brass colored mount at the top but on yours I can, but I really don't think that's it.
Harleyvh
Post by Harleyvh »
Thanks for the comments on the pictures.
it's definitely hard to see anything wrong form these.
More infor on this situation:
Installed my winter tires this weekend.
205/55/16 on my original 16" Metis
drove around and no "spring noise"....
the winter tires are more noisy so...
went to the famous test curve..... no "spring sound"...
so I went again and really wiped it around (fast enough for the rear end to swiing out) and.... no sound
:shock:
Looks like the "spring sound" is limited to my summer set-up
17" enkei with 235/45/17 tires.
it could be noted that the rear never lost it with this set up...
Totally confused.
2001 V70 2.4T - RIP
2004 V40 - "backup"
I am too...
DieselDoNicely
Post by DieselDoNicely »
Persistent sod isnt it, you have sprayed and checked everything I would have thought of and its still there.
Mine went though one of the yearly MOT tests here in the UK a few weeks back, if they can find a fault to cost/fail they will. No faults found and it is still has the bedspring noise.
DDN
1997 850 Turbo Diesel Auto Estate (390,000 miles)
2003 V70 D5(turbo diesel) Auto Estate - Powerflex poly wishbone bushed :-)
2005 V70 D5(turbo diesel) Geartronic Estate.
He said it went away....well at least for now, with no explanation except a wheel/tire change. I would say that if Murphy's law prevails (as usually it does) the sound will be back.
Harleyvh
Post by Harleyvh »
Murphy is right. The sound is still there but not as present.
It happens when the front end is faced with a road depression.
I observed it this morning on my way to work in a standard Quebec street in an industrial complex (as far away from a pool table as you can get it).
It did not happen on the highway in a depression situation as it used to happen with the summer set-up.
so it's quite specific. not too present. Probably related to spring/strut set-up. I'm finding my set-up a little too bouncy to my taste.. ..
Could it be related to the fact that the winter set-up (higher tiresidewall, smaller wheel, lighter weight, not as steady as summer set-up) is putting less stress on the front suspension?
food for thoughts.
2001 V70 2.4T - RIP
2004 V40 - "backup"
Harleyvh
Post by Harleyvh »
Update
Upgraded the front brakes last night.
The passenger side lower ball joint must be replaced.
Could this be the source of the "noise"....?
Anyway, replacement is planned for next tuesday.
Will keep you posted.
2001 V70 2.4T - RIP
2004 V40 - "backup"
