Hey guys - I've got the same situation with my 1994 850 Turbo. When he couldn't find easy access through the firewall, my shade tree mechanic friend mumbled something about using my cigarette lighter to hook up the wire coming from the amp in the trunk, and this really didn't seem like a good idea to me, but now I have validation! When my brother previously installed this amp & sub on my 240, he made a special point of buying the big-ass red wire and fuse and connecting it directly to the battery, and I figured there had to be a good reason. Incidentally, a few years back, this same mechanic friend lost a 240 to a fire that started in the tail lights. What really sucked was that all the green Volvo manuals and wiring diagrams that I'd bought for my '89 240 were in it. (Maybe I won't pay him in beer anymore.)
Thanks!
Michelle
Subwoofer
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
There's only one way to do automotive wiring, and that's the right way. Not a lot of room for mistakes when it's your car. It's one of those things you can't take shortcuts on or rig up.
I fried the wiring harness on my first car because I didn't know what I was doing. Luckily that was almost 20 years ago and the car was a pile anyway.
Never pass a wire through an opening that is bare metal. It will rub the insulation off of the wire.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
+1 with a bullet!
And never, ever, ever connect that big red wire to the battery without a fuse within a few inches!
"But there's a fuse on the amp..."
And there should be, but it won't keep your car from
burning up if the Big Red one shorts to ground.
Protect the wire running to the amp.
- BEJinFbk
A subwoofer amp uses a lot more juice than Volvo planned onbonmictx wrote:What about powering the amp using the supply to the power antenna, which I had my friend disconnect because it was hanging up all the time? I think it has a 25 amp fuse...
Michelle
sending to the power antenna. That wire is way too small.
You really need a properly sized cable to the amp all the way from the battery.
Don't forget the fuse!
Can you tell me the drawbacks to having too small a wire? Is it likely to keep blowing the fuse? Is there fire danger? My friend says there isn't, because it's powered through the fuse box. I need help arguing my point.
Thanks so much!
Michelle
Thanks so much!
Michelle
- BEJinFbk
I don't mean to sound harsh, but, this is car audio 101...
If your friend doesn't know why this is a bad plan,
that friend probably shouldn't be working on your car.
Amp won't maintain voltage, it may shut down.
Low voltage has occaisionally killed an amp.
Using a small wire to run a sub amp of any decent size is
kinda like trying to fill a swimming pool with a garden hose.
And you may want to double check what size fuse is supposed to be in that location.
25 sounds pretty big for a power antenna. Someone may have
put in a bigger one as a low budget "fix". That kinda thing can
cause melted electrical systems and other nasty problems.
Best of Luck!
Best of Luck!
Believe it or not, he's an ASE certified mechanic.BEJinFbk wrote:I don't mean to sound harsh, but, this is car audio 101...
From all that I've read on the amp wiring, including your advice, I've decided the reason he's gonna do it MY way is because the amp just won't perform like it should his way.
(FYI -I confirmed that the power antenna fuse is 30 amp, and that's what's listed in my owners manual.)
Thanks for your help!
Michelle
- 1288 Views
Last post by precopster
- 4033 Views
Last post by bigsi15
- 769 Views
Last post by v-45magna
- 1645 Views
Last post by IronMike
- 1583 Views
Last post by eapowers64
