Inspect the vacuum pump carefully. Since it sits under the battery it has been potentially subjected to a battery acid bath. That type of damage is clearly visible.Are some of these components known to be prone to failure
V70s for the '99 and '00 model years had Electronic Throttle (except the Euro-spec 10 Valve 5cyl models, which retained a traditional throttle), cruise was a software function with none of the usual cruise control parts, except the stalk. This was also the case for MSA 15.7- and 15.8-controlled diesel cars from '99 to '00.pebsham wrote:I think the systems are the same for all the 850's and the "classic" V70's up to 2000.
