Be sure when you remove the mast that the entire piece of spline comes out. If even a little piece has broken off in the motor, the new one will not go in.
In which case, you will need to remove the motor and remove the broken piece.
850 power antena
850 power antenna Won't Extend Up
SnookWhaler
- Year and Model:
1994 Volvo 850 sedan 165K
- Has thanked: 17 times
- Been thanked: 35 times
Shaking it upside down in this case seems to dislodge the pesky broken piece.
dwmeganbob
- Year and Model: 1998 s70 glt
SnookWhaler is exactly right, mine had about and 8" piece of mast broken off and stuck in the mast housing. No amount of shaking was going to dislodge a section that big(can't image ever shaking a piece out given the housing configuration).
Simple to fix: after removing assembly from car, just remove the two mount plate bolts on the bottom of the housing, then remove the center nut on the circular housing cover. Remove broken piece and reassemble.
- Oly850
- Year and Model: In acquisition mode.
- Has thanked: 53 times
- Been thanked: 22 times
I spent endless hours trying to get the antenna on my 850 working right, so I understand your agony here. In the end I just bought a $60 aftermarket antenna on eBay and it worked for years. Purists will scoff but it worked fine and I was able tho spend my time fixing my flame trap instead.
https://ebay.us/m/aMc6T2
Looking for a V90 to be my next Volvo, at the very least a T5.
2017 XC90 Inscription - My best Volvo by far, but Ex-wife departed & I had to sell.
2001 S80 T6 - rebuilt trans, head gasket, fixed & sold
1997 V70 - kid car, sold
1996 850 GLT - found under bridge, 2 year refurb project, commuter car, kid car, T-Boned - SIPS saved passenger. Totaled.
1997 VW GTI VR6 - exceedingly fast.
1971 VW Type II/231 - it was pointed out by management that the children would be killed in it.
- Has thanked: 2215 times
- Been thanked: 1853 times
I have a couple of brand new aftermarket ones and I think 1 or 2 P80 sedan ones, plus possibly a C70. The masts are different for some reason, but the main issue is the lower mount to the car has a different bracket that can be swapped.
I probably have about $40 (CDN)/ $30 US into the Volvo ones due to the cost of the masts these days, and the aftermarket ones, one I recall is a straight swap in and the other needed a couple of wires spliced but a simple mod. Those can go for $20 CDN ($15 US) each. Shipping will be on top of that of course.
If anyone wants on PM and we can sort it out. It will take me more time doing the cross border paperwork than packing and shipping!
I will test them prior to shipping to ensure they are working as they should as they have been stored in a heated garage for a while.
- 3059 Views
Last post by mika
- 1359 Views
Last post by 1337
- 4185 Views
Last post by jonesg
- 1339 Views
Last post by StupidS80
- 1963 Views
Last post by SuperHerman
