I would recomend checking your compression in each cylinder with a screw in type tester. Just to make sure the engine checks out mechanically. It seems odd that 4 injectors would fail to the point of not running all at the same time. Good luck with the car
Japedo
94 850 turbo
01 V70 XC
850 threw codes 300 303 304 305 the quit running
- Year and Model: Many Volvos
- Been thanked: 76 times
It sounds like you have all of the ingredients - fuel, spark, and compression. I notice that you said you replaced the cap and rotor. Hopefully you didn't use the diagrams in the Haynes manual for your plug wires - It is flat out wrong.Ihave replaced the dist cap and rotor.
Here is a link to the correct plug wire locations on the distributor.
http://volvospeed.com/Repair/sparkplugs.php
- 2763 Views
Last post by kevmcrae
- 26 Replies
- 4149 Views
Last post by j-dawg
- 3518 Views
- 11 Replies
- 2853 Views
Last post by Stark77
- 21 Replies
- 3384 Views
Last post by SuperHerman
