Volvo Term Glossary
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
hillsboro_eric, welcome to Matthew's Volvo Site.
To expand a little on 'limp mode', thanks to WikiAnswers:
Your engine management and maybe even your transmission is controlled by the ECU. As you know, all computers crash, all software has bugs, and mechanical equipment fails. As such, many ECU units are fitted with a 'limp home mode'. When it detects that something semi-serious is wrong, it enters the limp mode, which means that the engine won't rev beyond a pre-programmed speed, you can't accelerate very fast, or you may indeed be speed-restricted to 40 mph or similar. The transmission may even stay in one or two gears. Bad? Well, no, not really: The alternative would be to either let you drive at regular speeds, with the danger of letting you trash your car (expensive repair, means happy repair people, but angry driver), or stopping you from going anywhere (expensive recovery and stranded on the side of the road means happy recovery company, but angry driver).
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
evegreen
Year and Model: 1999 V70 XC 2.4L
Post by evegreen »
What does ECT mean?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
What does ECT mean?
Engine Coolant Temperature. It is normally used when referring the ECT Sensor.
Kent T
Year and Model: 1997 Volvo 960 Sedan
Post by Kent T »
964- 960 Sedan 4 door!
Brick- old school Volvo (many newer Volvos have some degree of Brick DNA). Affectionate term of Volvo lovers!
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
Turbobrick - an old school Volvo equipped with a turbocharger
Sportwagon - the 1995 855 T5-R, or more loosely, any turbocharged 855
Spirited Driving - conveyance at extralegal speeds, especially on non-freeway secondary highways. Associated with grinning.
5 others that came and went
VCA
Post by VCA »
There have been quite a few changes/additions to the module names with the newer cars, so I present an expanded list:
ACM - Alternator control module (post '07 cars)
ADM - Additive Dosing Module (diesel cars only)
AQS - Air Quality Sensor (cars with indoor air quality system)
AUD - AUDio Amplifier module (the speaker amp in post '07 cars with an Infotainment Control Module)
AUM - AUdio Module (the radio in post-'01 cars, but not post '07 P3x cars, and post '08 P2/P1 cars)
AUU - Accessory USB Unit (the iPod/USB interface in post '07 cars; present in '07-08s and in '09s that did not come from the factory with iPod connections)
BCM - Brake Control Module (was the ABS module in earlier cars)
BPM - Bluetooth Phone Module (the integrated Bluetooth receiver in post '07 cars)
BSC - Body Sensor Cluster (yaw/pitch sensors for DSTC)
CAN bus - the Controller Area Network bus that Volvos use
CCM - Climate Control Module
CEM - Central Electronic Module
CRM - Convertible Roof Module
CVM - Closing Velocity Module
DABM - Digital Audio Broadcast Module (Europe only)
DDM/PDM - Driver/Passenger Door Module (window switch packs on front doors of post-'01 cars)
ECM - Engine Control Module
ETA - Electronic Throttle Actuator (the "new" Bosch-made throttle in most '02 and newer cars)
ETM - Electronic Throttle Module (the Magnetti Marelli throttle in '99-02 cars)
FSM - Forward Sensing Module (used by the radar-guided cruise control)
GSM - Gear Selector Module (replaces PNP switch)
GPS - Global Positioning System (XC90)
HCM - Headlamp Control Module (used by the Active Bi-Xenons)
HLDF - High Level Display Front (the display unit in post '07 cars with park assist camera and/or nav)
IAM - Integrated Audio Module (the CD player/radio in post '07 ICM-equipped cars)
ICM - Infotainment Control Module (the LCD and radio control buttons on post '07 cars)
LCM/RCM - Left/Right Camera Module (BLIS only)
LIN bus - Local area INterconnect; a bus that ties low-speed communication together in newer Volvos (siren modules, some heated seat commands, etc.)
LSM - Light Switch Module
KVM - Keyless Vehicle Module (only present on cars with comfort access & keyless go)
MMM - MultiMedia Module (the navigation box in the trunk on post '07 IAM-equipped cars with RTI)
OWS - Occupant Weight Sensor (used by SRS)
PAC - Parking Assist Camera (the rearview camera connected to the HLDF)
PAM - Parking Assistance Module (the radar-equipped unit that offers front/rear park assist)
PBM - Parking Brake Module (cars with electric parking brake)
POT - Power Operated Tailgate (XC60, V70, XC70)
PSCM - Power Steering Control Module (cars with electrical power steering)
PHM - Phone Module (the integrated GSM phone on post '07 ICM-equipped cars)
PSM - Power Seat Module
RDAR - Remote Digital Audio Receiver (Sirius satellite radio receiver in post '07 cars)
REM - Rear Electronic Module
RKE - Remote Keyless Entry (post-'07 cars, cars with keyless vehicle)
RRX - Remote Receiver (post-'07 cars, cars without keyless vehicle)
RSE - Rear Seat Entertainment
RTI - Road Traffic Information (satellite navigation)
SAS - Steering Angle Sensor
SCU - Start Control Unit (ignition switch/slot, post-'07)
SRM - Sunroof control module
SUB - Subwoofer Module (XC60, V70, XC70, XC90)
SUM - SUspension Module (found on P2 'R' models and cars with 4C)
SWM - Steering Wheel Module (connects steering wheel controls to CAN bus)
TCM - Transmission Control Module
TRM - Trailer Module
TVM - Television Module (cars with Sensus entertainment, post-'11)
UEM - Upper Electronic Module (it's inside the mirror in post-'01 except certain C70s, and all P3x vehicles)
VGLA - Volvo Guard Lock & Alarm (found on pre-'01 cars)
2008 S80 T6 AWD
1999 S70 GLT
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Thanks VCA, I'll get that updated.
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
Kcody and VCA, got those in there. Cheers!
Also -> Amazon link
Davie Motors
Year and Model: all models
Post by Davie Motors »
VERY HELPFUL THANK YOU
philopus
Year and Model: 850 2.3 Turbo, 1994
Post by philopus »
'PTC' Positive Temperature Coefficient (heater nipple)
