1998 S70 GLT 130,000 miles - A few Issues
- Has thanked: 17 times
- Been thanked: 35 times
Pinned your other thread... I'll put a link in it for this one in case any other information here would be helpful to others.
If you're talking about tubes coming from under the crank pulley, those are oil cooler lines that go up to the radiator (passenger side). These are metal to the rear, flexible in the middle and metal going into the radiator. My car had one leaking at the metal/flex connection which you can see better from above the engine. They might also leak at the location where they go into the oil thermostat (I didn't know I had one). There are O rings on the ends of the lines. You can see the ends of the lines by shining a light down past the pulley and serpentine belt. The oil thermostat is a small metal unit that bolts on the engine below the crank pulley and fairly close to the engine mount on the passenger side. If you need to replace them, the job is a little tricky. I have some photos that might help. They are kinda expensive, so unless you can confirm a leak, I would leave them alone.Also, here is some kind of oil tube apperattus coming out from under the balancer that has oil residue on it like it has been leaking vary slightly. What is that thing and how do i fix it?
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
