I think you have either a bad master fuel system relay or a bad connection to the master fuel system relay. The relay will trigger the IAC valve which will emit a constant buzzing sound just below the throttle body with the key in position II. It also turns on the power to the fuel injectors.
The relay is gray in color an it lives on the US driver's side of the fan shroud. Very carefully inspect the wiring to the relay - that seems to be where the problems occur more than the relay itself.
The sound and the location of the noises that you are hearing is in the vicinity of the IAC valve and it would explain everything.
93 850 with 256k stalls and won't start
- Year and Model: Many Volvos
- Been thanked: 75 times
Re: 93 850 with 256k stalls and won't start
Hey guys, this is the exact same problem that my neighbor is experiencing with his high milage 1994 850. What I don't understand is if it is a fuel issue why can't we get it to at least try to start with starting fluid? Yellow spark to plugs coil tests ok.
If the IAC valve isn't working it can keep it from starting. Do you hear a buzzing sound next to the throttle body when the key is in position II?What I don't understand is if it is a fuel issue why can't we get it to at least try to start with starting fluid?
Have you pulled the codes from A-2 and A-6?
If the IAC valve is buzzing consistently with the key in position II the relay is working.
I got my fuel injector main relay delivered in about 30 hrs!
It did not fix the problem. I should have tested the old one before I ordered. I have just now finished testing the old one.
You can see that the relay has four terminals, namely 30,87, 85 and 86.
Visit this site anyone who is unfamiliar with relays.
http://www.classictruckshop.com/clubs/e ... /relay.htm
I used a 9 volt battery on 85 and 86 which caused the relay to
click closed, that is, the resistance 30 - 87 went from infinite to
virtually zero. The signal voltage between 85 and 86 controls the flow of current between 30 and 87. I suppose the relay could be bad by virtue of having
slowed down in its response time. I any case neither new or old
relay produced a start.
A2 has been clear of any codes for several days, I believe there were
zero codes there when I started working on this stall, I am not totally sure of that. A6 had many , many 3-1-4 codes. I have cleared A6 of all codes just now.
Any suggestions welcome. Thanks for you patience.
confused_al
- Year and Model: 1996 TLA wagon
If 3-1-4 (Camshaft Position sensor (CMP) signal missing or faulty) keeps coming back, either the sensor itself or the connector/wire is bad. Wouldn't you think?
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
I tried again to start the 850 with a fully charged battery. A2 and A6 were totally empty of codes both before and after the try. The car did turned over well but did not even cough. Half way through the 20 second crank I tried some Starter fluid in intake. Below are the readings I got.
Fuel Injector Main Relay Connector 4-Female
Wires going out below page
____________
| 87 30 |
| 85 86 |
87 Thick Green
30 Thick Red
85 Thin Brownish
86 Thick Red
With Ignition Off
Wire To Grnd Volt To Grnd Ohms
87 0.0 1590
30 12.6 16 Meg
85 0.0 infinite
86 12.6 16 Meg
With Ignition ON
87 0.0
30 12.6
85 0.0
86 12.6
Test done later with weak battery at 12.6 Volt
____________
| 87 30 |
| 85 86 |
87 Thick Green
30 Thick Red
85 Thin Brownish
86 Thick Red
With Ignition Off
87 0.0 1590
30 12.6 16 Meg
85 0.0 infinite
86 12.6 16 Meg
With Ignition ON
87 0.0
30 12.6
85 0.0
86 12.6
Hey guys, tonight we installed a new egr valve on my neighbors 850. Fired right up. The plastic housing was cracked on top and broken more on the bottom. Many people told me that a bad egr valve would not keep it from starting, but we made an executive decision and replaced it anyway. This car has sat for 3 months and we have worked on it off and on. The car never threw a egr code. All I know is that I have learned way too much about volvos. I need to stick to my small block Chevies with their carbs and distributors.
Thanks for being here for guys like me.
peace Bud
peace Bud
- 260 Views
Last post by br0dy519
- 1303 Views
Last post by ThekurgansheaD
