The fuel pump and the fuel system is a bit different on the XC / AWD series cars than a standard 850 so I am not speaking from experience.
On the plain'o 850s your symptoms could point to a bad check valve in the fuel pump. The way to tell is to hook up a fuel pressure gauge on the schrader valve, get the car to start, and run, and then turn it off. Take a look at the fuel pressure after the car is turned off. If it falls of rapidly you either have a bad check valve in the fuel pump or a bad fuel pressure regulator.
On the 850's the check valve is integral to the fuel pump assembly which means that you can't just change the pump motor itself to fix it and you need to buy the entire assembly. On the 850s the fuel pressure regulator is vacuum controlled and the diaphragm can breach and not only will it not maintain fuel pressure but it sucks raw gas into the vacuum line. If your fuel pressure regulator is vacuum controlled remove the vacuum line and look for signs of gas in the line itself, it shouldn't be there.
Volvo S70 AWD Diagnostic
- Year and Model: Many Volvos
- Been thanked: 76 times
pmarinello
- Year and Model: S70 AWD 1999
Is this correct, because tomorrow I will test the pressure at the Rail. Also what is the proper way of checking?misha wrote: Fuel pressure at first prime,before starting engine should be 43.5psi-max.At idle is a little lower..about 35-40psi and when you drive with a full throttle(pedal to the floor)43.5psi.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Yes,it's correct,but everything about 35-40 psi is acceptable.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
pmarinello
I just tested the fuel pressure with the relay jumped it was 375kpa which is in spec. and the residual value was fine. But then when I used the relay it was 340-355 which is out of spec and residual value is fine. New Relay? or what?
- misha
With relay jumped...375kpa
With relay not jumped...340-355psi.
Sounds like bad relay to me,but if it's bad you wouldn't be able to start or drive a car.
I would wait for response of any of the moderators,just to be sure.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
pmarinello
Does anyone have any idea's of what the problem may be?
Leave the fuel pump relay jumpered and see how it drives. If it behaves then the relay is your problem.
pmarinello
When I jump the relay the pump runs constantly is that safe I don't want to burn the pump out
It runs constantly when the car is running anyway.
pmarinello
Same thing when I pump the relay. What could this possibly be, this is really starting to kill me. I'm starting to run out of ideas.
- 2484 Views
Last post by RickHaleParker
- 565 Views
Last post by jonesg
- 4603 Views
- 14 Replies
- 11474 Views
Last post by North42g
- 1771 Views
