PAG Oil
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
did it specify a weight for the PAG oil in the VADIS?
It depends on the compressor model number. Some call for PAG 46 and others call for PAG 100.
Here is a link to the chart.
http://www.aa1car.com/library/pagoil.htm
outdoor7or24
Year and Model: SOLD 95 855t,93 945t
Post by outdoor7or24 »
Thanks Lee.
jonesboy1983
Year and Model: V70 2007
Post by jonesboy1983 »
Since I am going to have a mechanic recharge the system should I just tell them I have replaced the evaporator and accumulator and then they will replace the PAG oil or is that not standard?
Post by Ozark Lee »
As a general rule they will not automatically add the oil but I'm sure they can if you ask them to.
se4n
Year and Model: 1998 V70 GLT
Post by se4n »
I need to add some PAG oil to my system, but cannot find any reference to the make or model on the compressor itself. The car is a 98 V70 GLT.
I looked at every part of the compressor I can see from above and below the car. The only info I can see are the numbers "0659" stamped in the compressor housing on the bottom, and the the number "15" with a circle around it cast into the housing on the side toward the front of the car. Where would the tag be that would specify the make and model? My local O'Reilly's carries both 46 and 100 weight PAG oil in the cans you can put in through the low pressure port. I just need to figure out which one to get.
Post by Ozark Lee »
I show that the compressor for all '98 models should be a DKS15CH which takes PAG 46.
alexk243
Year and Model: 1993
Post by alexk243 »
Any idea for a Zexel 506491-2991?
Couldn't find any of the other numerals that are given on that chart.
1993 Volvo 850 (w/97' engine in it)
Post by Ozark Lee »
That number doesn't cross to anything. Is the compressor from the '93 or did the one from the new engine get installed?
As you know the '93 models are their own animal.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
He didn't post the key numbers. For anyone else wondering what numbers you need, see his other thread for a pic:
https://www.matthewsvolvosite.com/forums ... =1&t=56515
alexk243
Post by alexk243 »
Its the 93. Dont think the AC compressor was crossed over. That is the only numbers I can see on the tag. No other identifiers.
