Fault in the engine electronic system
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Re: Fault in the engine electronic system
Post by misha »
Enjoy the ride! :wink:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
marginal
Year and Model: V70 D5 2003
Has thanked: 1 time
Post by marginal »
Ozark Lee wrote:The indicator is called a "Lambda" light which is the same as the Check Engine light that we have here in the US. Fixing the ABS module generally won't impact the lambda light. In order find out which systems your car is not happy with you need to have the codes read from the OBD-II port.
I have both of them in my car :roll: ...
misha
Post by misha »
marginal wrote:I have both of them in my car :roll: ...
How is that possible to have both of them...check engine light & lambda light?
Or....you wanted to say that you have check engine light and abs/tracs light on?
Which is it?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
marginal
Has thanked: 1 time
Post by marginal »
I have both the "Lambda" light and the "Check engine" light.
The odometer is not the original one, I changed it about a month ago ...
misha
Post by misha »
I don't understand....
Lambda light is actually check engine light for every country in the world except u.s.a.
-Check engine light or MIL(malfunction indicator light) for u.s market.
-Lambda light for all countries except u.s.a.
Meaning...check engine light & lambda light are the same lights,with the same purpose,for different markets.
Why would you have both lights that meaning the same? :shock:
In order to solve this dilemma...can you please post pictures of those lights from your instrument cluster?
I'm very curious to see that.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
marginal
Has thanked: 1 time
Post by marginal »
Sorry.
I made a mistake.
It is not "Check engine" it is something different, but I forgot, now it is soooo gold here I can not go out and check it again.
I'll come back to tell you, it is something like "service-engine" ...
There is a dash "-" in the middle.
It is right bottom light ...
I'll write it down and post it here.
misha
Post by misha »
That's service light.It's ONLY oil change reminder. :wink:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
marginal
Has thanked: 1 time
Post by marginal »
Thanks.
And how do I reset it?
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
OBD II scanner.
marginal
Has thanked: 1 time
Post by marginal »
Well, I just read a lot about it and it seemss just an OBDII scanner (that I have and have tried without success) is not enough.
It takes this: http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... K:MEWAX:IT
But istead of spending money on it, I think I'll just take off the bulb :roll: ...
