1994 440 No start
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
I am leaning more and more to a faulty ignition switch. Try testing as I described in my previous post.
Bill.
In this test were you running a lead from the battery to the starter motor and was the ignition switch on or off? To get a spark you need the ignition on.I have held the coil wire away from a good earth, while supplying power to the starter & no spark is seen.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Hi happy new year to you, & thanks once again for your reply. Yes the ignition was turned on & I was supplying power from the battery. I also notice the ptrol gauge seems to keep going up to full, which I believe it to be & then dropping down to empty. Dont know wether this is connected. Cheers Reg
- billofdurham
With the petrol gauge playing games I am leaning more than ever towards the ignition switch.
You may be able to pick up a used one at a breaker's yard. If you want a used one with a warranty try Parts Gateway or CP Motors.
Bill.
Bill.
Previously:
Previously:
- 15982 Views
Last post by Medusalith
- 16794 Views
Last post by volvolugnut
- 9704 Views
Last post by zoli440
- 16185 Views
Last post by pastoralia
- 11047 Views
Last post by andyb440
