fs 98 v 70parts
BrianFaheyofMGfame
- Year and Model: 96 855T,98V70,97 855
Need; I have a (beautiful) high miles, dark green, '98 V70 AWD wagon. Hit a deer and need a driver's side, front fender and possibly a hood, and definitly a LF headlight and turn signal assy. Possibly needs a turbocharger, because it smokes when started but calms down after it gets warm? (Could this maybe just need the PCV kit?)
Have a N/A, dark metalic blue, 855 (GLT trim wagon) (170K mi) for parts that was hit in the left rear (just enough to barely kill it) for parts. If I snatch off the entire front clip will it fit on the '98 V70? In the end, all of this car will be parted out/ traded out and then scrapped, so frame cuts are not out of the question.
Have my beloved red 96 855T wagon (225K mi) that still runs like a scalded cat, but its now got some banged-up panals (both driver's side doors plus a tree limb put a small dent next to the tail light). Bought it brand new so there are some heart strings still attached to it. Off-white seats are not pretty any more. Off to college it went, but a few months later it had to be towed home, because after it's been quietly running 5-10 minutes, the valves start to clatter away and the oil pressure light flickers, then stays on. Peeking into the oil filler 'hole' I can see oil flying around, but it makes the 'running out of precious bodily fluids' noise, so I shut her down. Is the engine toast? And if-so, should I swap out the good N/A 855 engine and harness above. Hopfully there is a way to save the turbo engine and part out the N/A engine. In any event, need to fix what I can and sell what I can't; money has become a huge factor.
Also have 4 Borbett 5 spoke wheels with Blizzak tires mounted on them for sale. Tires are OK and were on for less than two winters. Summer use would eat these soft tires up in a couple of thrill rides.
Yea, and as my name implies- I've got a barn full of MGs and TRs Spitfires in various stages of decomposistion that should someday find new homes.
message_by_bike
- Year and Model: 1998 v70R
Do you have the front skid plate/air guide? price?
Hi,
I have a 1998 S70 T5. I believe the inner door handle assemblies are consistent between the models. I need them for both sides (driver/passenger). Please let me know if you have them.
A picture of them can be found here, care of this forum.
http://www.fototime.com/CFFEEFC4628C6CD/standard.jpg
I do not need the actual door handles, just the rest of the assembly.
[email protected]
Thanks! Hope to hear from you soon.
[email protected]
JRL
- Year and Model: Several
- Been thanked: 16 times
Would sure be nice if you posted the MODEL, color (especially the interior) and mileage
I'm looking for dark taupe door panels that aren't separated
