Thank you for the "Good Oil" especially billofdurham.
My daughters Volvo 240 Gl has stood for several years with little use and the brake warning light is now on.
No leaks and the brakes are soft.
Puzzled my mechanic but fluid has not been changed for years and moisture uptake is most likely cause.
Will now bleed and replace.
Again Thank you Ron
1990 240 DL "Brake Failure" Light and Excessive Pedal Tr
rgk
- Year and Model: Gray 88 245
- Has thanked: 1 time
If brakes are firm when pedal is pumped, but slowly travels to floor when car is stopped (say at a red light), that is most certainly a leaking master cylinder.
rgk -- was dickdeadly
May I use some led lights in my car ? Is it a good idea ?RicksBrick wrote:The brake failure light came on in my 89 240DL recently. It turned out to be the brake junction box. I had it replaced, the light went out and have had no problems since.
- 2447 Views
Last post by mknoll10
- 22 Replies
- 21184 Views
Last post by Willber
- 1213 Views
Last post by imaV70Rdriver
- 4756 Views
Last post by SUBdude
- 1483 Views
Last post by T64me
