Synthetic Oil vs. Regular Oil, which is better?
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Change to synthetic and don't add magic solutions, lubricants etc. Modern oils are more than capable of lubricating all parts of the engine, including seals. Also, change your oil frequently, especially if you have a turbo. On my NA 850 I change it every 3 -5 K miles.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
3000 miles is really unnecessary almost no matter what your driving is like. It's a myth, long debunked. All the brand name synthetic oils can do at LEAST 5K with no issues. Most can do 7.5K easily and 10K depending on the oil. Even if you punch your turbo a lot, 5-7.5 K is just fine.
Also, synthetic oil does not "dry out" seals. The only case where a car might leak after switching to synthetic is because the engine is in POOR shape to begin with. If you really want a seal conditioner in the oil, just buy oil that already has that sort of formula in the add-pack (usually the "high-mileage" products).
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
850 Turbo1
- Year and Model: 1996 Volvo 850
ALWAYS go with synthetic for a Turbo
Dyno oil is great for a non turbo Volvo
1996 850 T5 Sedan
1996 850 T5 Platinum Edition Wagon
--Always Learning--MB--
polskamafia mjl
ecbsykes, I know it might be considered overkill. I guess I see it this way, just because I can do something doesn't mean I should. I can run my car until it runs out of gas and then refill it, but it is much easier to fuel up before I run out. I like to change the oil every 3k since it doesn;t hurt anything and the engine loves it. Win-win in my book.
I got into a debate with a BMW service manager when he tried to tell my gf to let her bimmer run 18k before changing the oil. I guess you could do it if you want to but it doesn't do any good for the engine and $25 3-4 times a year really isn;t a big expense. My 2 cents...
- Marcin
- Marcin
850 Turbo1
Those service managers...really should be trained in something other than deceiving customers into getting unnecessary services. They don't have a clue ...half the time...about what they are talking about (or trying to talk you into).polskamafia mjl wrote:ecbsykes, I know it might be considered overkill. I guess I see it this way, just because I can do something doesn't mean I should. I can run my car until it runs out of gas and then refill it, but it is much easier to fuel up before I run out. I like to change the oil every 3k since it doesn;t hurt anything and the engine loves it. Win-win in my book.I got into a debate with a BMW service manager when he tried to tell my gf to let her bimmer run 18k before changing the oil. I guess you could do it if you want to but it doesn't do any good for the engine and $25 3-4 times a year really isn;t a big expense. My 2 cents...
- Marcin
Oil changes (if you want to be VERY kind to your car)...should be done every 3000 Kms.
Hey what better way to kill your bimmer... than delay an oil change by 15000 miles.
1996 850 T5 Sedan
volvomileage
- Year and Model:
some engine designs will tolerate extended oil changes with specific syth oils
as for these volvos the manual recommends sythetic oils, i use a syth oil in my high mileage brick, i have no leaks and i am pretty shure the engine runs much cleaner also,with better lube especialy in winter on startup, synthetics have come a long way, i wouldnt use a syth in a 60's american v8, but in recent volvo engine its a great choice, combined with a mann or volvo filter you are only helping out your engine for more mileage,but synthetic dosent last forever either regular oil changes are needed also you can stretch but d ont exagerate my 2 cents
cheers !
cheers !
volvo 850 95 sedan non/turbo 185 k
There does not seem to be a way to delete a post. I was trying to reply to a question on spark plugs, but after I logged in it brought me to this thread instead. I posted without checking the subject line and now I am trying to delete this post.
While I am here, I will say for the record, I use Mobil 1 10W-30 in all of my Volvos.
1998 S70, 5 speed manual, 146k, wife's car
1997 850 Wagon, 5 speed manual, 185k, son's car
1996 850 5 speed manual, 220k
1985 MB 300D 268k, running on B20 biodiesel
1983 MB 300D 240k , converted to vegetable oil
1981 VW Vanagon 184k
- 3049 Views
Last post by Uree
- 32 Replies
- 2731 Views
- 13 Replies
- 5471 Views
- 1499 Views
Last post by FLXC90
- 3502 Views
Last post by MadeInJapan
