If you are going to remove the dash pad all the way yes. The passenger air bag stays with the dash pad. There is a airbag connector and two 10mm bolts that will be disconnected. as long as you disconnect the battery before doing the job you will be ok as to not store any codes. There should be a link with instuctions available somewhere on here.Saint Matthew wrote:and do you need to do anything special in relation to the airbags when tinkering with the dash to get to the odometer?
Odometer Not Working '96 850
voltech1
- Year and Model: 2000 V70R
- Has thanked: 2 times
96 855 turbo 235k
00' v70r 156k w/blown motor
Really no need to take it all the way out. You should be able to lift the left side just enough to get the odometer out with a helper...I just used some wood blocks to hold it up from the middle- the left side needs to come way up.
- pkc303
- Year and Model: 1995 T-5R Yellow
- Has thanked: 1 time
- Been thanked: 3 times
I wasn't aware they made a T5 R in 1996.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
- 2016 Views
Last post by Ozark Lee
- 1337 Views
Last post by rspi
- 3205 Views
Last post by polskamafia mjl
- 1642 Views
Last post by precopster
- 751 Views
Last post by interace2
