Good suggestion, i actually pulled the entire cruise control control circuit when it first started happening thinking maybe it was related, but it didn't have any effect.
Not sure about the alternator, but the idle speeds at start up and at warm up and when in neutral have all been really consistent with the idle before the problem started occurring.
Does anyone know if there is there any way to eliminate the vacuum system as a potential culprit? Is there any specific things that happens when the brake or clutch are slightly depressed that would point to the system/s that might be malfunctioning?
- jreidko
93 Volvo 850 engine revs high by itself
Marcobrick
- Year and Model: 2003 V70T5
- Has thanked: 3 times
Quite a tricky problem. The only thing I can think of that the clutch pedal has anything to do with is the cruise control.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
Retired MVS Contributor
The throttle regulates the amount of air into the intake manifold, thereby controlling speed...Any air entering the intake AFTER the throttle will cause a high rev...The throttle body-to-intake manifold gasket would be most suspect as well as the intake manifold gasket itself...Also the "O" ring on the vacuum distributer mounted on the top of the throttle body...Your problem is almost certainly vacuum related, just where is the problem...Unmetered air is getting in somewhere...
Thanks Jerrymcc, your comment gives me a new place to look. I've had the intake and some of the throttle related components on and off enough that it seems very plausible that i could have introduced a weak point somewhere. I'll post what i find.
Thanks again everyone, - jreidko
z31jaime
- Year and Model: 1995 850 turbo wagon
Glad to see I'm not the only one with this issue.
After searching and with the Help of ROBTHEMODD we found on Volvoforums a thread of people that had the same issue. IT turned out to be the water Temp. sensor. THE sensor tells the car its "cold" and the IACV starts to pump to warm the car and revs it to 4k rpm trying to heat the water....
Most of them said they noticed the TEMP guage in the car go dead when the Reving happens...so check that. What I did was when the car was reving @ 4k RPM I pulled the Plug for the IACV...and Bam the car dropped to normal idle. so I knew It had to do with that, and it wasnt a vac leak or anything like that. I wasn't throwing CEL because thats a normal function of the car, to warm the motor.
I pulled one for the junk yard and suddenly CEL came on for low coolent temp. and the reving went from 4k to only 2k. so I knew I was looking in the correct place. I decided to clean the contact of the sensor because it was in a junk yard and exposed and noticed that the female side of the plug (attached to cars harness) was not looking good. IT has the same rubber insulation as the Injector relay that gets brittle and causes loose contacts so I pushed the wires up and they right out of the plug so i knew it was bad. I connected each wire by itself to the sensor then slid the plastic part over it all and so far today I havent had the reving issue.
sorry its a long story but I figured the more detail the better. I tried a NEW ECU< MAF< AND IACV and it looks to have been just a plug. GOOD LUCK>
Thanks for the thought z31jaime.
I have actually tried pulling the connection to the IACV and it didn't cause the revving to stop. But i hadn't tried looking at the temp gauge or the temp sensor itself. Looking for this gremlin has been such a pain since it only happens periodically. I've been compiling a list of things to try next time it does it and based on what you mentioned maybe i'll try pulling the connection to the temp sensor and see if that changes anything.
Cheers, hope to report back before it's below zero here in Chicago. - jreidko
sariano
- Year and Model: '96 850R Sportswagon
Do you have any problems with your car not starting after this happens? Our 850 revs high off and on then will not start if we shut it down, wait time is 20 minutes (somewhat annoying).
96' 850R Wagon
96' 850R Sedan
95' 850 T5-R Sedan
96' 850R Sedan
95' 850 T5-R Sedan
GoinFor300KMi
- Year and Model: 1996 Volvo 850 N/A
jreidko - it looks to me like your Throttle Position Sensor has failed. I missed reattaching mine while putting things together after doing a PCV job. The TPS on my N/A engine is difficult to see - its underneath the throttle body and I didn't notice the plug lying loose. Anyway, when I started the engine I had accelerating idle just like you describe. My '96 has OBDII, it gave me P0120 and P0123 codes so I knew instantly what the problem was. I think the 93 is different, no OBD, but you have some kind of error codes. A new TPS costs 50 to 100 bucks and is easy to replace but it would be nice if you can verify that's what the problem is.
Hey Sariano,
When my 850 does the revving it will start without a problem. You might check your main relay, it's mounted right above the radiator under the lip of the plastic cover that sits across the front of the engine compartment behind the hood latch.
I had a problem where my car would randomly die and then wouldn't start for 5/10/15 minutes and replacing the main relay and the fuel pump relay was what fixed it.
-jreidko
-jreidko
Hey GoinFor300KMi, i'm not getting any engine codes, but i will take a look and verify that the TPS sensor is hooked up properly. On the 93' 850 it's OBD-I where you can pull codes by watching a blinking red LED in the engine compartment.
Cheers - Jreidko
Cheers - Jreidko
- 23 Replies
- 3575 Views
Last post by DaveenBavari
- 308 Views
Last post by svetjana
- 2770 Views
Last post by MadeInJapan
- 303 Views
- 17 Replies
- 4702 Views
Last post by Clemens
