Mystery Oil Leak (lots of pictures)
vantassell
Year and Model: 1998 V70 GLT
Post by vantassell »
holler1 wrote:Did the leak start right after you did the PCV? The reason I ask is that I'm wondering if the short stubby hose might have a leak where it attaches to the engine block. That seems to be the area where most of the oil is. You might check it for looseness or a crack. Also, was the block opening where that hose goes clean or might it be clogged?
Ding ding ding! You are right. Ha ha, good guess. I just barely found that I did bust that hose. The leak more or less started when I did the PCV fix. I think before I was causing a leak because of the blocked PCV, and I fixed that one but at the same time started another by ripping the hose. So, it kind of seemed to me that I didn't fix the original leak.
holler1
Post by holler1 »
Congratulations! It's great when you actually find a specific problem and can fix it. When I changed my PCV a lot of gunk had collected in those engine passages and I had to scrape it out. I checked to make sure the passages were open to the sump by shoving in a rubber hose until I "struck oil".
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
