Power Antenna Repair- a few questions
viper69
Year and Model: 850GLT 1995
Has thanked: 70 times
Been thanked: 2 times
Re: Power Antenna Repair- a few questions
Post by viper69 »
Ozark Lee wrote:All you need to remove is the nut at the top of the mast. The base of the mast has a ferrule that wants to get stuck in the socket but all and all it is very easy - a 1 wrencher. The hardest part is getting the new mast spline to bite into the motor gears - it may take a few shots.
The instructions on the bag are actually very helpful.
Thanks..I just pulled it open..there was a fair amount of black "sludge" in between some of the teeth. However nothing major, I cleaned it off, and that didn't help any. I think the motor itself is OK.
QUESTION. After I undid the nut on the black rubber antenna mount, the old spline remains inside the housing. How does one take it out??? I'm clearly missing something very simple or obvious. I didn't want to pull on the spline, because I concerned about potentially damaging the gears of the antenna motor itself. For something so simple..this is a real pain.
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
viper69
Post by viper69 »
Any suggestions or ideas on my last question?
Volvo 850 GLT 1995
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Are there any bent sections on the mast?
Even the slightest bend will hang the system up. You can bend things back by hand.
viper69
Post by viper69 »
No there are not...none that I've detected. I certainly haven't driven by anything to get it bent either.
Volvo 850 GLT 1995
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
The spline "belt" is attached to the mast.
It's driven by a gear in the motor, but that's all that "connects" it to the motor.
With the nut removed and the cap broken loose, have an assistant turn the radio
on to raise the antenna. Then just pull up at the motor's feed rate and keep on pullin'.
BE SURE to note the direction of the spline teeth when you remove it!
You'll need to orient the spline the same direction for reinstallation.
When you reinstall, it's the same only backwards. Get the motor pulling down,
( turn the radio off so the motor "lowers") feed the spline into it and let it pull it in.
Reassemble and tighten! :wink:
viper69
Post by viper69 »
BEJinFbk wrote:The spline "belt" is attached to the mast.
Thank you, I know the spline is attached to the mast, and I understand what you mean about feeding it in and taking it out. But here's what doesn't make sense to me.
As the motor is only on for a given amount of time, that means the spline can only travel a certain length. If that's the case, how does one feed in the appropriate length of spline?? Someone is going to say "turn the radio on and off 20 times." I've seen that posted elsewhere for the Volvo on the internet.
However, what I don't understand is if I am able to feed in a given amount for example 3 inches (im making this up), and I need 6 inches of spline in then, After I turn ON the radio a 2nd time, it will push out the spline, and my 3 inches will be spit out, then when I turn it off, it will take up 3 inches again. So in a given ON/OFF radio cycle it will give me a net movement of zero.
It's not that I don't believe you haha...It's that I don't understand exactly, as illustrated by my example.....Further clarification?? Sorry.. :roll:
Volvo 850 GLT 1995
BEJinFbk
Post by BEJinFbk »
I haven't had one of those apart for a while, but I can tell you it's not timed.
As long as the radio is on, it gets power to a DPDT relay that reverses the motor
when power is cut. Then when the motor reaches "end of travel", it shuts off.
IIRC, there's a set of contacts in there that detects the torque at the clutch
or the two ends of the antenna. I wish I had a better answer...
Again, it's been ages since I opened one of those things up, but I don't remember
a timing circuit. There's a cheaper, electro-mechanical way to cut power.
You may just have a drive unit fulla crud or a broken chunk of spline in there.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1245 times
Post by matthew1 »
Just for anyone following this saga at home: antenna mast lubrication is a service item in the 850 manual, and probably a service item for S70/V70/XC70/C70 models with a telescoping mast as well.
Also -> Amazon link
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Nah. The motor runs for about 30 seconds or so, it should give you enough time to get the strip in there within a few tries. As BEjinFBK said, it then gives up when it reaches a certain resistance.
So, basically, once you get it to grab, if it doesn't take it all in on the first try, turn the radio on and off again (quickly - it will reverse the direction of the motor), and it should go all the way down by itself. Screw the nut down, then make sure it goes up, and done!
Matt, that's in the manual for the S70 as well. It's something that's easy to forget about til it starts making noise, or destroys itself in the winter.
'98 S70 T5
2016 Chevy Cruze Premier
viper69
Post by viper69 »
Ahh I see..I'll give it a go...IF the spline is not exactly lined up..do I run the risk of chewing up bits of new spline and having them get caught up in the gears of the motor?
Volvo 850 GLT 1995
